Tang Band W8-740P 8" Subwoofer
Brand:|Model: W8-740P|Part # 264-854
The W8-740P is one of the highest excursion 8" subwoofers available on the market. It utilizes a heavy-duty paper cone, foam surround, and bumped back plate for maximum mechanical movement.
List Price$101.67
You Save23%
$78.21
Buy 4+$74.30
Part # 264-854
  • One of the highest excursion 8" subwoofers available on the market
  • Heavy-duty paper cone
  • Bumped back plate for maximum mechanical movement
The W8-740P is one of the highest excursion 8" subwoofers available on the market. It utilizes a heavy-duty paper cone, foam surround, and bumped back plate for maximum mechanical movement. The 2" 4-layer voice coil, vented pole piece, and heavy-duty aluminum voice coil former provide impressive power handling. Excellent for small-enclosure home or automotive subwoofers.
  • Nominal Diameter8"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)300 Watts
  • Impedance4 ohms
  • Frequency Response28 to 1,000 Hz
  • Sensitivity84 dB 1W/1m
  • Voice Coil Diameter2"
  • Magnet Weight50 oz.
  • Resonant Frequency (Fs)28 Hz
  • DC Resistance (Re)3.2 ohms
  • Voice Coil Inductance (Le)3.18 mH
  • Mechanical Q (Qms)10.53
  • Electromagnetic Q (Qes)0.3
  • Total Q (Qts)0.3
  • Compliance Equivalent Volume (Vas)0.81 ft.³
  • Mechanical Compliance of Suspension (Cms)0.33 mm/N
  • BL Product (BL)13.35 Tm
  • Diaphragm Mass Inc. Airload (Mms)95g
  • Maximum Linear Excursion (Xmax)12 mm
  • Surface Area of Cone (Sd)220 cm²
  • Cone MaterialPaper
  • Surround MaterialFoam
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.27"
  • Baffle Cutout Diameter7.25"
  • Depth4.75"
  • # Mounting Holes8
  • Sealed Volume0.11 ft.³
  • Sealed F380 Hz
  • Vented Volume0.25 ft.³
  • Vented F350 Hz
  • BrandTang Band
  • ModelW8-740P
  • Part Number264-854
  • UPC844632009822
    (65 Reviews)
  • Weight10.5201 lbs.
View similar products to the Tang Band W8-740P 8" Subwoofer
