Tang Band W8-1853 8" Neodymium Poly Woofer
Brand:|Model: W8-1853|Part # 264-895
The W8-1853 subwoofer features a powerful but compact neodymium motor, poly injected cone, low-loss foam rubber surround, and vented pole piece.
Part # 264-895
The W8-1853 subwoofer features a powerful but compact neodymium motor, poly injected cone, low-loss foam rubber surround, and vented pole piece. Superb bass performance from a 3" deep driver. Suitable for any application that demands high output/low distortion sub bass output, yet is restricted by space considerations: in-wall, mobile audio, and more.
  • Nominal Diameter8"
  • Power Handling (RMS)100 Watts
  • Power Handling (max)200 Watts
  • Impedance4 ohms
  • Frequency Response37 to 350 Hz
  • Sensitivity86 dB 1W/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)37 Hz
  • DC Resistance (Re)3.4 ohms
  • Voice Coil Inductance (Le)0.54 mH
  • Mechanical Q (Qms)5.95
  • Electromagnetic Q (Qes)0.33
  • Total Q (Qts)0.31
  • Compliance Equivalent Volume (Vas)0.63 ft.³
  • Mechanical Compliance of Suspension (Cms)0.26 mm/N
  • BL Product (BL)13.01 Tm
  • Diaphragm Mass Inc. Airload (Mms)69.85g
  • Maximum Linear Excursion (Xmax)5.25 mm
  • Surface Area of Cone (Sd)220 cm²
  • Cone MaterialPoly
  • Surround MaterialFoam
  • Magnet MaterialNeodymium
  • Overall Outside Diameter8.26"
  • Baffle Cutout Diameter7.19"
  • Depth2.97"
  • # Mounting Holes8
  • Sealed Volume0.09 ft.³
  • Sealed F3102 Hz
  • Vented Volume0.21 ft.³
  • Vented F364 Hz
  • BrandTang Band
  • ModelW8-1853
  • Part Number264-895
  • UPC844632079054
  • Weight3.74 lbs.
View similar products to the Tang Band W8-1853 8" Neodymium Poly Woofer
