Tang Band W8-1363SBF 8" Paper Cone Subwoofer Speaker
Brand:|Model: W8-1363SBF|Part # 264-920
A big performer with a small footprint, the Tang Band W8-1363SBF 8" subwoofer driver will pump out high-output, low-distortion low frequency output wherever required—home, office, or mobile.
List Price$120.83
You Save23%
$92.95
Buy 4+$88.30
Part # 264-920
High impact bass performance requires the linear excursion provided by the Tang Band W8-1363SBF 8" subwoofer. This unique, high-powered driver's wide half-roll surround, raised flat spider, bumped back plate, and large 2" 4-layer voice coil deliver an Xmax value of 12 mm—just what you need for serious, deep, clean bass output! The W8-1363SBF's vented pole piece and vented spider promote voice coil cooling by maximizing heat dissipation and reducing power compression.
  • Nominal Diameter8"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)300 Watts
  • Impedance4 ohms
  • Frequency Response30 to 800 Hz
  • Sensitivity83 dB 1W/1m
  • Voice Coil Diameter2"
  • Magnet Weight42.3 oz.
  • Resonant Frequency (Fs)30 Hz
  • DC Resistance (Re)3.2 ohms
  • Voice Coil Inductance (Le)0.82 mH
  • Mechanical Q (Qms)3.88
  • Electromagnetic Q (Qes)0.35
  • Total Q (Qts)0.32
  • Compliance Equivalent Volume (Vas)0.67 ft.³
  • Mechanical Compliance of Suspension (Cms)0.28 mm/N
  • BL Product (BL)13.29 Tm
  • Diaphragm Mass Inc. Airload (Mms)99.78g
  • Maximum Linear Excursion (Xmax)12 mm
  • Surface Area of Cone (Sd)220 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.62"
  • Baffle Cutout Diameter7.21"
  • Depth5.16"
  • # Mounting Holes8
  • Sealed Volume0.12 ft.³
  • Sealed F374 Hz
  • Vented Volume0.25 ft.³
  • Vented F346 Hz
  • BrandTang Band
  • ModelW8-1363SBF
  • Part Number264-920
  • UPC844632092886
    (1 Reviews)
  • Weight9.9 lbs.
View similar products to the Tang Band W8-1363SBF 8" Paper Cone Subwoofer Speaker
