Tang Band W69-1042J 6"x9" Subwoofer
Brand:|Model: W69-1042J|Part # 264-837
The oval shaped frame of the W69-1042 gives you the surface area of a typical 8" driver in the footprint of a 6-1/2". Perfect for constructing a space saving narrow-baffle subwoofer. Also performs well in automotive installs in 6" x 9" locations.
List Price$85.12
You Save23%
$65.47
Buy 4+$62.20
Part # 264-837
  • Oval shaped frame gives you the surface area of a typical 8” driver in the footprint of a 6-1/2”
  • Perfect for constructing a compact narrow-baffle subwoofer
  • High power handling and long excursion for excellent low-bass performance
  • Also suitable for use in automotive applications
The oval shaped frame of the W69-1042 gives you the surface area of a typical 8" driver in the footprint of a 6-1/2". Perfect for constructing a space saving narrow-baffle subwoofer. Also performs well in automotive installs in 6" x 9" locations. High power handling and long excursion for excellent low-bass performance.
Note: Modifications may be required for mounting in factory 6" x 9" openings
  • Nominal Diameter6" x 9"
  • Power Handling (RMS)90 Watts
  • Power Handling (max)170 Watts
  • Impedance8 ohms
  • Frequency Response35 to 350 Hz
  • Sensitivity87 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Magnet Weight29.2 oz.
  • Resonant Frequency (Fs)35 Hz
  • DC Resistance (Re)6.5 ohms
  • Voice Coil Inductance (Le)0.91 mH
  • Mechanical Q (Qms)3.93
  • Electromagnetic Q (Qes)0.4
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)1.07 ft.³
  • Mechanical Compliance of Suspension (Cms)0.42 mm/N
  • BL Product (BL)13.27 Tm
  • Moving Mass Of Diaphragm (Mmd)49.89
  • Maximum Linear Excursion (Xmax)7.3 mm
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Overall Outside Diameter6.5" x 9.2"
  • Baffle Cutout Diameter5.5" x 8.25"
  • Depth4.18"
  • # Mounting Holes4
  • Sealed Volume0.25 ft.³
  • Sealed F385 Hz
  • Vented Volume0.65 ft.³
  • Vented F351 Hz
  • BrandTang Band
  • ModelW69-1042J
  • Part Number264-837
  • UPC844632009815
    (28 Reviews)
  • Weight6.2601 lbs.
View similar products to the Tang Band W69-1042J 6"x9" Subwoofer
