Tang Band W6-1139SIF 6-1/2" Paper Cone Subwoofer Speaker
Brand:|Model: W6-1139SIF|Part # 264-919
The Tang Band W6-1139SIF 6-1/2" driver will surprise and impress when installed in subwoofer systems for compact home theater systems, multimedia setups, and mobile audio installations.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$62.81
You Save23%
$48.32
Buy 4+$45.90
Part # 264-919
  • 11.5 mm xmax, amazing low frequency capability for a driver this small!
  • Wide half-roll surround, raised flat spider, and large 1-1/2" 4-layer voice coil ensure exceptional output
  • Vented pole piece and vented spider promote voice coil cooling
  • Features a rugged stamped steel basket and bumped back plate
The Tang Band W6-1139SIF 6-1/2" subwoofer's wide half-roll surround, raised flat spider, and large 1-1/2" 4-layer voice coil ensure exceptional output and high power handling. Boasting 11.5 mm of Xmax, the W6-1139SIF is capable of producing prodigious amounts of deep, low-distortion, punchy bass. A vented pole piece and vented spider promote voice coil cooling by improving heat dissipation and reducing efficiency-robbing power compression. This 4 ohm driver also features a rugged stamped steel basket and bumped back plate.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance4 ohms
  • Frequency Response35 to 800 Hz
  • Sensitivity83 dB 1W/1m
  • Voice Coil Diameter1.52"
  • Magnet Weight29.2 oz.
  • Resonant Frequency (Fs)35 Hz
  • DC Resistance (Re)3.6 ohms
  • Voice Coil Inductance (Le)0.47 mH
  • Mechanical Q (Qms)2.65
  • Electromagnetic Q (Qes)0.47
  • Total Q (Qts)0.4
  • Compliance Equivalent Volume (Vas)0.42 ft.³
  • Mechanical Compliance of Suspension (Cms)0.6 mm/N
  • BL Product (BL)8.47 Tm
  • Diaphragm Mass Inc. Airload (Mms)39.91g
  • Maximum Linear Excursion (Xmax)11.5 mm
  • Surface Area of Cone (Sd)140 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.95"
  • Baffle Cutout Diameter5.57"
  • Depth4.33"
  • # Mounting Holes4
  • Sealed Volume0.13 ft.³
  • Sealed F370 Hz
  • Vented Volume0.33 ft.³
  • Vented F338 Hz
  • BrandTang Band
  • ModelW6-1139SIF
  • Part Number264-919
  • UPC844632092879
    (22 Reviews)
  • Weight5.95 lbs.
View similar products to the Tang Band W6-1139SIF 6-1/2" Paper Cone Subwoofer Speaker
