Tang Band W6-1139SI 6-1/2" Subwoofer
Brand:|Model: W6-1139SI|Part # 264-832
Amazing bass in a compact package! This one-of-a-kind 6-1/2" subwoofer has an impressive 13 mm of Xmax.
List Price$119.46
You Save23%
$91.89
Buy 4+$87.30
Part # 264-832
  • Long-throw, high-power design for more bass -- 13 mm Xmax!
  • Paper cone with oversized roll
  • Neodymium magnet with vented pole piece
  • Steel basket
  • Magnetically shielded
Amazing bass in a compact package! This one-of-a-kind 6-1/2" subwoofer has an impressive 13 mm of Xmax. A wide roll surround, raised flat spider, and large 1-1/2" 4-layer voice coil ensure impressive bass performance and high power handling. Venting the pole piece and spider allows good airflow around the coil, improving heat dissipation and reducing power compression. The compact neodymium motor structure saves valuable enclosure space while also allowing closer-than-normal placement to CRTs. The ultimate multimedia subwoofer driver!
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance4 ohms
  • Frequency Response38 to 800 Hz
  • Sensitivity83 dB 1W/1m
  • Voice Coil Diameter1.52"
  • Resonant Frequency (Fs)38 Hz
  • DC Resistance (Re)3.6 ohms
  • Voice Coil Inductance (Le)0.34 mH
  • Mechanical Q (Qms)2.65
  • Electromagnetic Q (Qes)0.47
  • Total Q (Qts)0.4
  • Compliance Equivalent Volume (Vas)0.42 ft.³
  • Mechanical Compliance of Suspension (Cms)0.42 mm/N
  • BL Product (BL)8.67 Tm
  • Diaphragm Mass Inc. Airload (Mms)39.91g
  • Maximum Linear Excursion (Xmax)13 mm
  • Surface Area of Cone (Sd)140 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter6.95"
  • Baffle Cutout Diameter5.57"
  • Depth4.29"
  • # Mounting Holes4
  • Sealed Volume0.11 ft.³
  • Sealed F381 Hz
  • Vented Volume0.31 ft.³
  • Vented F346 Hz
  • BrandTang Band
  • ModelW6-1139SI
  • Part Number264-832
  • UPC844632019333
    (66 Reviews)
  • Weight3.84 lbs.
View similar products to the Tang Band W6-1139SI 6-1/2" Subwoofer
Videos
