Tang Band W57-1781 5" x 7" Poly Woofer
Brand:|Model: W57-1781|Part # 264-891
Tang Band's W57-1781 features an exciting form factor that permits designers to optimize bass reproduction in unusually shaped places. The classic 5" x 7" chassis may be loaded singly or in close-coupled groups to achieve desired output.
ORDER TODAY
Ships in 60-90 days, minimum order quantity 300 pcs.
List Price$53.09
Part # 264-891
Call For Pricing
866-366-4909 (Toll Free)
Tang Band's W57-1781 features an exciting form factor that permits designers to optimize bass reproduction in unusually shaped places. The classic 5" x 7" chassis may be loaded singly or in close-coupled groups to achieve desired output. Other key construction points include a structured black PPM cone terminated with wide-temperature range rubber surround, nylon composite basket, vented pole piece, and large ceramic ferrite magnet. Also great for automotive and indoor/outdoor multimedia applications.
  • Nominal Diameter5"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance8 ohms
  • Frequency Response40 to 500 Hz
  • Sensitivity87 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)40 Hz
  • DC Resistance (Re)7.2 ohms
  • Voice Coil Inductance (Le)0.38 mH
  • Mechanical Q (Qms)2.12
  • Electromagnetic Q (Qes)0.3
  • Total Q (Qts)0.27
  • Compliance Equivalent Volume (Vas)0.92 ft.³
  • Mechanical Compliance of Suspension (Cms)0.97 mm/N
  • BL Product (BL)10.35 Tm
  • Diaphragm Mass Inc. Airload (Mms)19.96g
  • Maximum Linear Excursion (Xmax)3 mm
  • Surface Area of Cone (Sd)140 cm²
  • Cone MaterialPoly
  • Surround MaterialRubber
  • Basket / Frame MaterialPolymer
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.71" x 5.20"
  • Baffle Cutout Diameter5.2"
  • Depth3.27"
  • # Mounting Holes4
  • Sealed Volume0.11 ft.³
  • Sealed F3121 Hz
  • Vented Volume0.21 ft.³
  • Vented F378 Hz
  • BrandTang Band
  • ModelW57-1781
  • Part Number264-891
  • UPC844632079016
  • Product CategoryWoofers
  • Weight4 lbs.
View similar products to the Tang Band W57-1781 5" x 7" Poly Woofer
Part # 264-891
Call For Pricing
