Tang Band W5-876SE 5" Shielded Subwoofer Driver 16 Ohms
Brand:|Model: W5-876SE|Part # 299-135
This Tang Band-made, 5" shielded subwoofer features a 16 ohm impedance for parallel use in MTM speakers, quad-array parallel subwoofers, and for center channel speakers. The extended response allows it to be used with a tweeter!
Part # 299-135
  • 16 ohm impedance for parallel driver MTM and center channel speakers
  • Create a compact, quad-driver array, 4-ohm subwoofer
  • High power handling
  • Great Xmax
  • Extended frequency response for use with tweeters in 2-way cabinets
Tang Band designed this 5" shielded subwoofer for making compact vented bass systems, giving it extra excursion, a high-power voice coil, vented pole piece, special twin-roll surround, and a rigid cone. The 16-ohm impedance, and extended response, makes it suitable for use in MTM and center channel multimedia speaker systems. Wire four in parallel for a low distortion, 4-ohm compact subwoofer with amazing output!
Single driver cabinet recommendation:
• Vented 0.25 cubic ft. (net internal, not including driver or port volume) tuned to 60 Hz with a 2" Precision Port that is 9" long, which yields an f3 of 60 Hz
Two drivers wired in parallel (8-ohm) cabinet recommendation:
• Vented 0.5 cubic ft. (net internal, not including driver or port volume) tuned to 60 Hz with a 3" Precision Port that is 9.5" long, which yields an f3 of 60 Hz
Four drivers wired in parallel (4-ohm) cabinet recommendation:
• Vented 1.0 cubic ft. (net internal, not including driver or port volume) tuned to 60 Hz with a 4" Precision Port that is 7" long, which yields an f3 of 60 Hz
  • Nominal Diameter5"
  • Power Handling (RMS)40 Watts
  • Power Handling (max)80 Watts
  • Impedance16 ohms
  • Frequency Response60 to 2,000 Hz
  • Sensitivity87 dB 1W/1m
  • Voice Coil Diameter1.25"
  • Resonant Frequency (Fs)57 Hz
  • DC Resistance (Re)12.26 ohms
  • Voice Coil Inductance (Le)4.168 mH
  • Mechanical Q (Qms)3.84
  • Electromagnetic Q (Qes)0.42
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)0.3 ft.³
  • Maximum Linear Excursion (Xmax)5 mm
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.125"
  • Baffle Cutout Diameter4.875"
  • Depth3.75"
  • Sealed Volume0.08 ft.³
  • Sealed F3120 Hz
  • Vented Volume0.2 ft.³
  • Vented F367 Hz
  • BrandTang Band
  • ModelW5-876SE
  • Part Number299-135
  • UPC848864002774
  • Product CategoryWoofers
    (3 Reviews)
  • Weight5.2 lbs.
View similar products to the Tang Band W5-876SE 5" Shielded Subwoofer Driver 16 Ohms
