Tang Band W5-1611SAF 5" Full Range Speaker
Brand:|Model: W5-1611SAF|Part # 264-918
Versatility and fidelity are the Tang Band W5-1611SAF 5" speaker's chief attributes. It is small enough to offer articulation and great HF dispersion, but big enough to pack a punch.
List Price$65.41
You Save23%
$50.32
Buy 4+$47.80
Part # 264-918
  • Underhung design for low distortion and quick transient response
  • Aluminum pole piece increases dispersion
  • Accurate, smooth frequency response
The Tang Band W5-1611SAF 5" speaker has a fiberglass-reinforced nylon frame, black polypropylene cone, and wide temperature range/high-loss rubber surround. An underhung 1" voice coil provides linear travel and the aluminum pole piece phase plug improves dispersion. The W5-1611SAF's extremely smooth, extended frequency response makes it suitable for a variety of applications, including full-range point source loudspeaker systems, line arrays, and midrange duty.
  • Nominal Diameter5"
  • Power Handling (RMS)28 Watts
  • Power Handling (max)56 Watts
  • Impedance8 ohms
  • Frequency Response60 to 20,000 Hz
  • Sensitivity90 dB 1W/1m
  • Voice Coil Diameter1"
  • Magnet Weight18.6 oz.
  • Resonant Frequency (Fs)60 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)0.02 mH
  • Mechanical Q (Qms)2.8
  • Electromagnetic Q (Qes)0.52
  • Total Q (Qts)0.44
  • Compliance Equivalent Volume (Vas)0.41 ft.³
  • Mechanical Compliance of Suspension (Cms)1.31 mm/N
  • BL Product (BL)5.53 Tm
  • Diaphragm Mass Inc. Airload (Mms)5.99g
  • Maximum Linear Excursion (Xmax)3 mm
  • Surface Area of Cone (Sd)94 cm²
  • Cone MaterialPoly
  • Surround MaterialRubber
  • Basket / Frame MaterialPolymer
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.18"
  • Baffle Cutout Diameter5.16"
  • Depth3.44"
  • # Mounting Holes4
  • Sealed Volume0.17 ft.³
  • Sealed F3109 Hz
  • Vented Volume0.44 ft.³
  • Vented F356 Hz
  • BrandTang Band
  • ModelW5-1611SAF
  • Part Number264-918
  • UPC844632092862
  • Product CategoryWoofers
    (12 Reviews)
  • Weight3.8 lbs.
View similar products to the Tang Band W5-1611SAF 5" Full Range Speaker
