Tang Band W4-992C 4" Subwoofer 2 Ohm
Brand:|Model: W4-992C|Part # 299-825
This unique 4", 2 ohm subwoofer, from Tang Band, is designed to provide excellent bass response in a small package. A heavy-duty paper cone, rigid dustcap, and twin-roll surround allow linear and distortion-free cone movement. Save up to 56% off the original retail price!
Part # 299-825
  • Heavy-duty 4" subwoofer with under spider venting
  • Unique multi-roll rubber surround for controlled excursion
  • Low Qts design for use in ported subwoofer designs
  • 2 ohm impedance for use in sets of two, four, or eight
Tang Band designed the unique W4-992C 4", 2 ohm subwoofer speaker to provide excellent bass response in a small package. While it may look similar to the other 4" drivers, the cone, voice coil, surround, and motor have been optimized for higher-power bass applications. High power tinsel leads and venting under the spider yield maximum thermal capacity. At the same time, a heavy-duty paper cone, rigid dustcap, and twin-roll surround allow linear and distortion-free cone movement.
This subwoofer is great for mini 2.5 or 3-way speakers, a 2-way design with a robust tweeter, and as a miniature computer subwoofer. The 2 ohm impedance allows for a wide array of wiring configurations: wire four in series for an 8 ohm load, eight in series-parallel for a 4 ohm load for maximum bass in minimum space. Perfect for modern audio applications, such as a subwoofer speaker bar to suppliment the bass in thinner sound bars. Save up to 56% off the original retail price through this Parts Express exclusive buyout. Hurry, quantities are limited!
  • Nominal Diameter4"
  • Power Handling (RMS)28 Watts
  • Power Handling (max)56 Watts
  • Impedance2 ohms
  • Frequency Response55 to 3,000 Hz
  • Sensitivity86 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)52 Hz
  • DC Resistance (Re)1.93 ohms
  • Voice Coil Inductance (Le)0.57 mH
  • Mechanical Q (Qms)4.53
  • Electromagnetic Q (Qes)0.40
  • Total Q (Qts)0.37
  • Compliance Equivalent Volume (Vas)0.16 ft.³
  • BL Product (BL)6.43 Tm
  • Diaphragm Mass Inc. Airload (Mms)7g
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Surface Area of Cone (Sd)62 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter4.50"
  • Baffle Cutout Diameter3.50"
  • Depth2.50"
  • Bolt Circle Diameter4.25"
  • # Mounting Holes4
  • Sealed Volume0.04 ft.³
  • Sealed F3113 Hz
  • Vented Volume0.10 ft.³
  • Vented F364 Hz
  • BrandTang Band
  • ModelW4-992C
  • Part Number299-825
  • UPC848864015187
    (5 Reviews)
  • Weight1.9000 lbs.
View similar products to the Tang Band W4-992C 4" Subwoofer 2 Ohm
