Tang Band W4-1757SB 4" Aluminum Cone Driver
Brand:|Model: W4-1757SB|Part # 264-881
Aluminum honeycomb sandwich cone, durable foam half-roll surround, shielded neodymium magnet, and extremely wide off-axis frequency response.
List Price$119.05
You Save23%
$91.58
Buy 4+$87.00
Part # 264-881
  • Aluminum honeycomb sandwich cone
  • Durable foam half-roll surround
  • Extremely wide off-axis frequency response
Aluminum honeycomb sandwich cone, durable foam half-roll surround, shielded neodymium magnet, and extremely wide off-axis frequency response. Ultra-shallow frame requires only 2" of mounting depth.
  • Nominal Diameter4"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance6 ohms
  • Frequency Response75 to 20,000 Hz
  • Sensitivity86 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)75 Hz
  • DC Resistance (Re)5.6 ohms
  • Voice Coil Inductance (Le)0.02 mH
  • Mechanical Q (Qms)1.55
  • Electromagnetic Q (Qes)0.65
  • Total Q (Qts)0.46
  • Compliance Equivalent Volume (Vas)0.15 ft.³
  • Mechanical Compliance of Suspension (Cms)0.91 mm/N
  • BL Product (BL)4.51 Tm
  • Diaphragm Mass Inc. Airload (Mms)4.99g
  • Maximum Linear Excursion (Xmax)3 mm
  • Surface Area of Cone (Sd)57 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter4.26"
  • Baffle Cutout Diameter3.8"
  • Depth2.36"
  • # Mounting Holes4
  • Sealed Volume0.06 ft.³
  • Sealed F3139 Hz
  • Vented Volume0.18 ft.³
  • Vented F372 Hz
  • BrandTang Band
  • ModelW4-1757SB
  • Part Number264-881
  • UPC844632078897
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (5 Reviews)
  • Weight1.45 lbs.
View similar products to the Tang Band W4-1757SB 4" Aluminum Cone Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
