Tang Band W4-1320SJF 4" Bamboo Full Range Speaker
Brand:|Model: W4-1320SJF|Part # 264-915
The Tang Band W4-1320SJF 4" speaker's bamboo cone provides exquisite audio performance, and the truncated cast aluminum frame reduces space between baffle edges or adjacent drivers.
List Price$48.44
You Save23%
$37.26
Buy 4+$35.40
Part # 264-915
Tang Band's W4-1320SJF 4" speaker features a bamboo fiber paper cone with half-roll rubber surround. This optimally damped cone material is rigid, lightweight, and durable. The driver's 18 oz. ceramic ferrite magnet and underhung 1" voice coil do their part to ensure very low 2nd and 3rd order distortion. A machined aluminum phase plug improves high frequency performance, and a strong cast aluminum chassis maintains proper component alignment. The W4-1320SJF's truncated frame edges permit close driver-to-driver spacing and reduced baffle frontal area. Also available in an easily recessed round frame version, the W4-1320SIF.
  • Nominal Diameter4"
  • Power Handling (RMS)25 Watts
  • Power Handling (max)50 Watts
  • Impedance8 ohms
  • Frequency Response75 to 20,000 Hz
  • Sensitivity88 dB 1W/1m
  • Voice Coil Diameter1"
  • Magnet Weight18.6 oz.
  • Resonant Frequency (Fs)75 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)0.02 mH
  • Mechanical Q (Qms)2.4
  • Electromagnetic Q (Qes)0.45
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)0.18 ft.³
  • Mechanical Compliance of Suspension (Cms)1.13 mm/N
  • BL Product (BL)5.14 Tm
  • Diaphragm Mass Inc. Airload (Mms)3.4g
  • Maximum Linear Excursion (Xmax)3 mm
  • Surface Area of Cone (Sd)57 cm²
  • Cone MaterialBamboo Fiber / Paper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter4.28"
  • Baffle Cutout Diameter3.76"
  • Depth3.24"
  • # Mounting Holes4
  • Sealed Volume0.05 ft.³
  • Sealed F3158 Hz
  • Vented Volume0.12 ft.³
  • Vented F388 Hz
  • BrandTang Band
  • ModelW4-1320SJF
  • Part Number264-915
  • UPC844632092831
  • Product CategoryWoofers
    (3 Reviews)
  • Weight3.65 lbs.
View similar products to the Tang Band W4-1320SJF 4" Bamboo Full Range Speaker
