Tang Band W4-1320SJ 4" Bamboo Cone Driver
Brand:|Model: W4-1320SJ|Part # 264-847
A blend of paper and Bamboo fibers provides a perfect combination of light weight and self-damping. A neodymium motor with a copper ring reduces distortion even further.
List Price$87.99
You Save25%
$65.80
Buy 4+$62.51
Part # 264-847
Another Tang Band first, Bamboo fiber cones! A blend of paper and Bamboo fibers provides a perfect combination of light weight and self-damping. A neodymium motor with a copper ring reduces distortion even further. The result of these features is a smooth frequency response with a very natural, open sound.
Specifications: • Power handling: 25 watts RMS/50 watts max • VCdia: 1" • Impedance: 8 ohms • Re: 6.8 ohms • Frequency range: 75-20,000 Hz • Fs: 75 Hz • SPL: 89 dB 1W/1m • Vas: 0.21 cu. ft. • Qms: 1.50 • Qes: 0.48 • Qts: 0.37 • Xmax: 3 mm • Dimensions: Overall diameter: 4-15/16", Cutout diameter: 3-3/4", Depth: 2-5/8".
  • Nominal Diameter4"
  • Power Handling (RMS)25 Watts
  • Power Handling (max)50 Watts
  • Impedance8 ohms
  • Frequency Response75 to 20,000 Hz
  • Sensitivity89 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)75 Hz
  • DC Resistance (Re)6.8 ohms
  • Voice Coil Inductance (Le)0.01 mH
  • Mechanical Q (Qms)1.29
  • Electromagnetic Q (Qes)0.49
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)0.21 ft.³
  • BL Product (BL)4.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)3.49g
  • Maximum Linear Excursion (Xmax)3 mm
  • Cone MaterialBamboo Fiber / Paper
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter4.28"
  • Baffle Cutout Diameter3.7"
  • Depth2.63"
  • # Mounting Holes4
  • Sealed Volume0.05 ft.³
  • Sealed F3169 Hz
  • Vented Volume0.11 ft.³
  • Vented F398 Hz
  • BrandTang Band
  • ModelW4-1320SJ
  • Part Number264-847
  • UPC844632070884
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (11 Reviews)
  • Weight1.55 lbs.
View similar products to the Tang Band W4-1320SJ 4" Bamboo Cone Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
