Tang Band W3-926SDF 3" Full Range Speaker
Brand:|Model: W3-926SDF|Part # 264-912
The Tang Band W3-926SDF 3" transducer is a great choice for single driver full-range applications and multiple speaker configurations such as line arrays.
Ships in 60-90 days, minimum order quantity 300 pcs.
List Price$29.28
Part # 264-912
Call For Pricing
866-366-4909 (Toll Free)
Tang Band's W3-926SDF 3" speaker features an attractive pincushion style stamped steel frame, lightweight poly cone, and a Santoprene rubber surround. The driver's solid aluminum phase plug and precisely matching moving parts give a smooth frequency response, wide dispersion, and good top end clarity and "air." A high-energy ceramic ferrite motor and extended voice coil improve low-end response.
  • Nominal Diameter3"
  • Power Handling (RMS)12 Watts
  • Power Handling (max)25 Watts
  • Impedance8 ohms
  • Frequency Response100 to 20,000 Hz
  • Sensitivity86 dB 1W/1m
  • Voice Coil Diameter0.8"
  • Magnet Weight8 oz.
  • Resonant Frequency (Fs)100 Hz
  • DC Resistance (Re)6 ohms
  • Voice Coil Inductance (Le)0.08 mH
  • Mechanical Q (Qms)5.86
  • Electromagnetic Q (Qes)0.54
  • Total Q (Qts)0.49
  • Compliance Equivalent Volume (Vas)0.07 ft.³
  • Mechanical Compliance of Suspension (Cms)1.3 mm/N
  • BL Product (BL)3.72 Tm
  • Diaphragm Mass Inc. Airload (Mms)1.2g
  • Maximum Linear Excursion (Xmax)0.75 mm
  • Surface Area of Cone (Sd)32 cm²
  • Cone MaterialPoly
  • Surround MaterialSantoprene®
  • Magnet MaterialFerrite
  • Overall Outside Diameter3.19"
  • Baffle Cutout Diameter3.05"
  • Depth2.13"
  • # Mounting Holes4
  • Sealed Volume0.04 ft.³
  • Sealed F3161 Hz
  • Vented Volume0.11 ft.³
  • Vented F378 Hz
  • BrandTang Band
  • ModelW3-926SDF
  • Part Number264-912
  • UPC844632092800
  • Product CategoryWoofers
  • Weight1.25 lbs.
View similar products to the Tang Band W3-926SDF 3" Full Range Speaker
Part # 264-912
Call For Pricing
