Tang Band W3-926SD 3" Poly Cone Neodymium Full Range Driver
Brand:|Model: W3-926SD|Part # 264-815
This driver has an attractive pincushion style silver frame, lightweight poly cone, solid aluminum phase plug, and a rubber surround. The precisely matching moving parts give a smooth frequency response and good top end clarity and "air."
List Price$32.29
You Save23%
$24.84
Buy 4+$23.60
Part # 264-815
This driver has an attractive pincushion style silver frame, lightweight poly cone, solid aluminum phase plug, and a rubber surround. The precisely matching moving parts give a smooth frequency response and good top end clarity and "air." Neodymium motor and longer voice coil for improved low-end response.
  • Nominal Diameter3"
  • Power Handling (RMS)12 Watts
  • Power Handling (max)25 Watts
  • Impedance8 ohms
  • Frequency Response110 to 20,000 Hz
  • Sensitivity87 dB 1W/1m
  • Voice Coil Diameter0.8"
  • Resonant Frequency (Fs)110 Hz
  • DC Resistance (Re)6 ohms
  • Voice Coil Inductance (Le)0.07 mH
  • Mechanical Q (Qms)5.38
  • Electromagnetic Q (Qes)0.5
  • Total Q (Qts)0.46
  • Compliance Equivalent Volume (Vas)0.07 ft.³
  • Mechanical Compliance of Suspension (Cms)1.3 mm/N
  • BL Product (BL)3.84 Tm
  • Diaphragm Mass Inc. Airload (Mms)2g
  • Maximum Linear Excursion (Xmax)0.75 mm
  • Surface Area of Cone (Sd)32 cm²
  • Cone MaterialPoly
  • Surround MaterialSantoprene®
  • Magnet MaterialNeodymium
  • Overall Outside Diameter3.19"
  • Baffle Cutout Diameter3.05"
  • Depth2.13"
  • # Mounting Holes4
  • Sealed Volume0.03 ft.³
  • Sealed F3192 Hz
  • Vented Volume0.09 ft.³
  • Vented F396 Hz
  • BrandTang Band
  • ModelW3-926SD
  • Part Number264-815
  • UPC844632009754
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (16 Reviews)
  • Weight0.5201 lbs.
View similar products to the Tang Band W3-926SD 3" Poly Cone Neodymium Full Range Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
