Tang Band W3-881SJF 3" Full Range Speaker
Brand:|Model: W3-881SJF|Part # 264-911
The Tang Band W3-881SJF is characterized by extended, very smooth frequency response. Its powerful ceramic magnet system and underhung voice coil contribute to extremely low distortion.
List Price$37.38
You Save29%
Buy 4+$24.83
Part # 264-911
The Tang Band W3-881SJF is an exceptional 3" transducer that features a PPM cone, Santoprene surround, cast aluminum frame, and powerful underhung-design ceramic motor. Its copper-clad aluminum wire voice coil is wound on a polyimide former, the combination of which provides high power handling and extended HF response. The W3-881SJF is an ideal choice for single driver full-range applications, as well as deployment in multiple speaker configurations such as line arrays.
  • Nominal Diameter3"
  • Power Handling (RMS)15 Watts
  • Power Handling (max)30 Watts
  • Impedance8 ohms
  • Frequency Response100 to 20,000 Hz
  • Sensitivity88 dB 1W/1m
  • Voice Coil Diameter0.8"
  • Magnet Weight7.7 oz.
  • Resonant Frequency (Fs)100 Hz
  • DC Resistance (Re)6.6 ohms
  • Voice Coil Inductance (Le)0.8 mH
  • Mechanical Q (Qms)6.44
  • Electromagnetic Q (Qes)0.41
  • Total Q (Qts)0.39
  • Compliance Equivalent Volume (Vas)0.07 ft.³
  • Mechanical Compliance of Suspension (Cms)1.32 mm/N
  • BL Product (BL)4.47 Tm
  • Diaphragm Mass Inc. Airload (Mms)2g
  • Maximum Linear Excursion (Xmax)0.5 mm
  • Surface Area of Cone (Sd)32 cm²
  • Cone MaterialPoly
  • Surround MaterialSantoprene®
  • Voice Coil Wire MaterialCCA
  • Magnet MaterialFerrite
  • Overall Outside Diameter3.66"
  • Baffle Cutout Diameter2.95"
  • Depth2.32"
  • # Mounting Holes4
  • Sealed Volume0.02 ft.³
  • Sealed F3207 Hz
  • Vented Volume0.05 ft.³
  • Vented F3115 Hz
  • BrandTang Band
  • ModelW3-881SJF
  • Part Number264-911
  • UPC844632092794
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (12 Reviews)
  • Weight1.5 lbs.
View similar products to the Tang Band W3-881SJF 3" Full Range Speaker
