Tang Band W3-881SJ 3" Cast Frame Neodymium Driver
Brand:|Model: W3-881SJ|Part # 264-812
Tang Band's 3" full range W3-881SJ offers high quality sound from 100 to 20,000 Hz. It features a powerful neodymium motor, cast aluminum basket, and a PPM cdone with Santoprene surround.
List Price$40.18
You Save29%
Buy 4+$26.69
Part # 264-812
This is an exceptional 3" driver featuring a PPM cone, rubber surround, cast aluminum frame, and self-shielded underhung neodymium motor. The small magnet size reduces harmful reflections behind the cone and makes installation in small enclosures much easier. This is an exceptional little driver, excelling at midrange and full-range applications.
  • Nominal Diameter3"
  • Power Handling (RMS)15 Watts
  • Power Handling (max)30 Watts
  • Impedance8 ohms
  • Frequency Response100 to 20,000 Hz
  • Sensitivity86 dB 1W/1m
  • Voice Coil Diameter0.75"
  • Magnet Weight0.4 oz.
  • Resonant Frequency (Fs)100 Hz
  • DC Resistance (Re)6.6 ohms
  • Mechanical Q (Qms)3.07
  • Electromagnetic Q (Qes)0.8
  • Total Q (Qts)0.63
  • Compliance Equivalent Volume (Vas)0.078 ft.³
  • Mechanical Compliance of Suspension (Cms)1.31 mm/N
  • BL Product (BL)2.9 Tm
  • Diaphragm Mass Inc. Airload (Mms)1.6g
  • Maximum Linear Excursion (Xmax)0.5 mm
  • Surface Area of Cone (Sd)32 cm²
  • Cone MaterialPoly
  • Surround MaterialSantoprene®
  • Magnet MaterialNeodymium
  • Overall Outside Diameter3.66"
  • Baffle Cutout Diameter2.95"
  • Depth1.77"
  • # Mounting Holes4
  • Sealed Volume0.11 ft.³
  • Sealed F3126 Hz
  • Vented Volume0.18 ft.³
  • Vented F364 Hz
  • BrandTang Band
  • ModelW3-881SJ
  • Part Number264-812
  • UPC844632019432
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (25 Reviews)
  • Weight0.5 lbs.
View similar products to the Tang Band W3-881SJ 3" Cast Frame Neodymium Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
