Tang Band W3-881SI 3" Speaker
Brand:|Model: W3-881SI|Part # 299-113
The Tang Band W3-881SJF 3" speaker is characterized by extended, very smooth frequency response. Its powerful neodymium magnet system and underhung voice coil contribute to extremely low distortion.
Part # 299-113
  • Rigid, lightweight PPM cone with Santoprene surround
  • Attractive "pincushion" stamped steel frame
  • Underhung voice coil and high-strength neodymium motor provide low distortion
  • Perfect for full-range mini-monitors, dedicated midrange, and line arrays
The Tang Band W3-881SI is an exceptional 3" transducer that features a PPM cone, attractive pincushion style stamped steel frame, Santoprene surround, and powerful underhung-design neodymium motor. Its copper-clad aluminum wire voice coil is wound on a polyimide former, the combination of which provides high power handling and extended HF response. An ideal choice for single driver full-range applications, as well as line arrays. Buyout, limited quantities.
  • Nominal Diameter3"
  • Power Handling (RMS)15 Watts
  • Power Handling (max)30 Watts
  • Impedance8 ohms
  • Frequency Response100 to 20,000 Hz
  • Sensitivity84.5 dB 1W/1m
  • Voice Coil Diameter0.75"
  • Resonant Frequency (Fs)106 Hz
  • DC Resistance (Re)6.6 ohms
  • Mechanical Q (Qms)7.17
  • Electromagnetic Q (Qes)0.96
  • Total Q (Qts)0.85
  • Compliance Equivalent Volume (Vas)0.05 ft.³
  • Maximum Linear Excursion (Xmax)0.5 mm
  • Cone MaterialPoly Composite
  • Surround MaterialSantoprene®
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialNeodymium
  • Overall Outside Diameter3.19"
  • Baffle Cutout Diameter3"
  • Depth2"
  • # Mounting Holes4
  • BrandFactory Buyouts
  • ModelW3-881SI
  • Part Number299-113
  • UPC844632095191
  • Product CategoryProducts
    (31 Reviews)
  • Weight0.3 lbs.
View similar products to the Tang Band W3-881SI 3" Speaker
in the Products product category.
