Tang Band W3-532SQF 3" Full Range Speaker
Brand:|Model: W3-532SQF|Part # 264-910
Extended, flat response and low distortion are leading features of the Tang Band W3-532SQF 3" speaker. Its truncated aluminum basket permits very closer driver spacing and ultra-compact enclosure designs.
ORDER TODAY
Ships in 60-90 days, minimum order quantity 300 pcs.
List Price$35.84
Part # 264-910
Call For Pricing
866-366-4909 (Toll Free)
Tang Band's W3-532SQF 3" speaker provides optimal performance when installed in full-range high fidelity speaker systems. Its PPM cone, Santoprene surround, truncated cast aluminum frame, and powerful ceramic motor are combined with an underhung copper-clad aluminum wire voice coil and polyimide former, guaranteeing superb performance. The W3-532SQF is ideally suited to single driver full-range applications and multiple speaker configurations such as line arrays.
  • Nominal Diameter3"
  • Power Handling (RMS)12 Watts
  • Power Handling (max)25 Watts
  • Impedance8 ohms
  • Frequency Response100 to 20,000 Hz
  • Sensitivity86 dB 1W/1m
  • Voice Coil Diameter0.8"
  • Magnet Weight4.2 oz.
  • Resonant Frequency (Fs)100 Hz
  • DC Resistance (Re)6.6 ohms
  • Voice Coil Inductance (Le)0.08 mH
  • Mechanical Q (Qms)4.37
  • Electromagnetic Q (Qes)0.87
  • Total Q (Qts)0.72
  • Compliance Equivalent Volume (Vas)0.05 ft.³
  • Mechanical Compliance of Suspension (Cms)1.06 mm/N
  • BL Product (BL)3.23 Tm
  • Diaphragm Mass Inc. Airload (Mms)2g
  • Maximum Linear Excursion (Xmax)0.5 mm
  • Surface Area of Cone (Sd)32 cm²
  • Cone MaterialPoly
  • Surround MaterialSantoprene®
  • Voice Coil Wire MaterialCCA
  • Magnet MaterialFerrite
  • Overall Outside Diameter3.19"
  • Baffle Cutout Diameter2.95"
  • Depth2.17"
  • # Mounting Holes4
  • Sealed Volume0.17 ft.³
  • Sealed F3110 Hz
  • Vented Volume0.17 ft.³
  • Vented F361 Hz
  • BrandTang Band
  • ModelW3-532SQF
  • Part Number264-910
  • UPC844632092787
  • Product CategoryWoofers
  • Weight1.05 lbs.
View similar products to the Tang Band W3-532SQF 3" Full Range Speaker
Part # 264-910
Call For Pricing
