Tang Band W3-1878 3" Full Range Driver
Brand:|Model: W3-1878|Part # 264-902
The Tang Band W3-1878 full-range driver features an underhung neodymium motor design that provides extended, linear response while reducing 2nd and 3rd harmonic distortion.
List Price$110.29
You Save23%
$84.84
Buy 4+$80.60
Part # 264-902
  • Full-range capability
  • Underhung voice coil
  • Neodymium magnet structure
  • Extremely low harmonic distortion
  • Bamboo fiber paper cone
  • Durable foam rubber surround
  • Unique aluminum phase plug
The Tang Band W3-1878 full-range driver features an underhung neodymium motor design that provides extended, linear response while reducing 2nd and 3rd harmonic distortion. The bamboo/paper cone is lightweight yet appropriately rigid and is terminated with a durable foam rubber half roll surround. A unique aluminum phase plug improves dispersion at the speaker's higher frequencies.
  • Nominal Diameter3"
  • Power Handling (RMS)12 Watts
  • Power Handling (max)25 Watts
  • Impedance8 ohms
  • Frequency Response75 to 20,000 Hz
  • Sensitivity88 dB 1W/1m
  • Voice Coil Diameter0.8"
  • Resonant Frequency (Fs)75 Hz
  • DC Resistance (Re)6.5 ohms
  • Voice Coil Inductance (Le)0.02 mH
  • Mechanical Q (Qms)1.67
  • Electromagnetic Q (Qes)0.34
  • Total Q (Qts)0.28
  • Compliance Equivalent Volume (Vas)0.11 ft.³
  • Mechanical Compliance of Suspension (Cms)2.12 mm/N
  • BL Product (BL)4.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)2g
  • Maximum Linear Excursion (Xmax)4.2 mm
  • Surface Area of Cone (Sd)32 cm²
  • Cone MaterialBamboo Fiber / Paper
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter3.66"
  • Baffle Cutout Diameter2.97"
  • Depth2.54"
  • # Mounting Holes4
  • Sealed Volume0.02 ft.³
  • Sealed F3212 Hz
  • Vented Volume0.03 ft.³
  • Vented F3135 Hz
  • BrandTang Band
  • ModelW3-1878
  • Part Number264-902
  • UPC844632088384
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (5 Reviews)
  • Weight1.8 lbs.
View similar products to the Tang Band W3-1878 3" Full Range Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
