Tang Band W2-852SH 2" Shielded Speaker Driver
Brand:|Model: W2-852SH|Part # 264-808
The W2-852SF is an elegant 2" driver featuring a paper cone and specially designed paper dustcap.
List Price$28.05
You Save23%
$21.58
Buy 4+$20.50
Part # 264-808
  • Unique full range design with a vented spider and S-roll surround
  • Resonant-resistant polymer frame
  • Dust cap is attached directly to the voice coil for improved high frequency response
The W2-852SF is an elegant 2" driver featuring a paper cone and specially designed paper dustcap. This rigid dustcap is attached directly to the voice coil, providing improved high frequency performance and increased effective surface area. A new cast polymer chassis allows allows for easier installation and a cleaner look. A vented spider, s-shaped surround, and shielded neodymium magnet round out the attributes. Great high frequency extension and good off-axis response makes this very capable as a mid-tweeter.
  • Nominal Diameter2"
  • Power Handling (RMS)8 Watts
  • Power Handling (max)16 Watts
  • Impedance4 ohms
  • Frequency Response160 to 20,000 Hz
  • Sensitivity86 dB 1W/1m
  • Voice Coil Diameter0.8"
  • Resonant Frequency (Fs)160 Hz
  • DC Resistance (Re)3.6 ohms
  • Voice Coil Inductance (Le)0.03 mH
  • Mechanical Q (Qms)1.49
  • Electromagnetic Q (Qes)0.37
  • Total Q (Qts)0.29
  • Compliance Equivalent Volume (Vas)0.008 ft.³
  • Mechanical Compliance of Suspension (Cms)1.05 mm/N
  • BL Product (BL)2.99 Tm
  • Diaphragm Mass Inc. Airload (Mms)1g
  • Maximum Linear Excursion (Xmax)1 mm
  • Surface Area of Cone (Sd)13 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Basket / Frame MaterialPolymer
  • Magnet MaterialNeodymium
  • Overall Outside Diameter2.24"
  • Baffle Cutout Diameter2.04"
  • Depth1.39"
  • # Mounting Holes4
  • Sealed Volume0.01 ft.³
  • Sealed F3431 Hz
  • Vented Volume0.01 ft.³
  • Vented F3272 Hz
  • BrandTang Band
  • ModelW2-852SH
  • Part Number264-808
  • UPC844632019418
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (6 Reviews)
  • Weight0.3 lbs.
View similar products to the Tang Band W2-852SH 2" Shielded Speaker Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
