Tang Band W2-803SM 2" Extended Range Speaker Driver
Brand:|Model: W2-803SM|Part # 264-805
A small 2" drive unit useable as a mid-tweeter or extended-range midbass. Features include a silver poly cone, ABS basket, solid aluminum phase plug, shielded neodymium motor, s-shaped surround, and venting under the spider.
List Price$27.23
You Save23%
$20.95
Buy 4+$19.90
Part # 264-805
A small 2" drive unit useable as a mid-tweeter or extended-range midbass. Features include a silver poly cone, ABS basket, solid aluminum phase plug, shielded neodymium motor, s-shaped surround, and venting under the spider. Great for A/V, multimedia, automotive, or multi-driver hi-fi use.
  • Nominal Diameter2"
  • Power Handling (RMS)8 Watts
  • Power Handling (max)16 Watts
  • Impedance4 ohms
  • Frequency Response160 to 20,000 Hz
  • Sensitivity85 dB 1W/1m
  • Voice Coil Diameter0.75"
  • Resonant Frequency (Fs)160 Hz
  • DC Resistance (Re)3.6 ohms
  • Voice Coil Inductance (Le)0.04 mH
  • Mechanical Q (Qms)3.56
  • Electromagnetic Q (Qes)0.46
  • Total Q (Qts)0.4
  • Compliance Equivalent Volume (Vas)0.008 ft.³
  • Mechanical Compliance of Suspension (Cms)1.05 mm/N
  • BL Product (BL)2.69 Tm
  • Diaphragm Mass Inc. Airload (Mms)0.87g
  • Maximum Linear Excursion (Xmax)1 mm
  • Surface Area of Cone (Sd)13 cm²
  • Cone MaterialPoly
  • Surround MaterialRubber
  • Basket / Frame MaterialPolymer
  • Magnet MaterialFerrite
  • Overall Outside Diameter2.24"
  • Baffle Cutout Diameter2.04"
  • Depth1.35"
  • # Mounting Holes4
  • Sealed Volume0.01 ft.³
  • Sealed F3314 Hz
  • Vented Volume0.01 ft.³
  • Vented F3168 Hz
  • BrandTang Band
  • ModelW2-803SM
  • Part Number264-805
  • UPC844632009716
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (18 Reviews)
  • Weight0.3201 lbs.
View similar products to the Tang Band W2-803SM 2" Extended Range Speaker Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
