Tang Band W2-1803S 2" Neodymium Poly Full Range Driver
Brand:|Model: W2-1803S|Part # 264-885
Miniature full-range transducer. Polypropylene diaphragm with Santoprene rubber surround. 9/16" aluminum voice coil and high-energy, lightweight neodymium magnet structure.
List Price$19.29
You Save23%
$14.84
Buy 4+$14.10
Part # 264-885
Miniature full-range transducer. Polypropylene diaphragm with Santoprene rubber surround. 9/16" aluminum voice coil and high-energy, lightweight neodymium magnet structure. Works well in small computer audio applications, or wherever tiny hi-fidelity drivers are required.
  • Nominal Diameter2"
  • Power Handling (RMS)3 Watts
  • Power Handling (max)6 Watts
  • Impedance6 ohms
  • Frequency Response155 to 20,000 Hz
  • Sensitivity82 dB 1W/1m
  • Voice Coil Diameter0.5625"
  • Resonant Frequency (Fs)155 Hz
  • DC Resistance (Re)5.6 ohms
  • Voice Coil Inductance (Le)0.08 mH
  • Mechanical Q (Qms)2.84
  • Electromagnetic Q (Qes)0.94
  • Total Q (Qts)0.7
  • Compliance Equivalent Volume (Vas)0.01 ft.³
  • Mechanical Compliance of Suspension (Cms)1.37 mm/N
  • BL Product (BL)2.12 Tm
  • Diaphragm Mass Inc. Airload (Mms)0.77g
  • Maximum Linear Excursion (Xmax)0.7 mm
  • Surface Area of Cone (Sd)13 cm²
  • Cone MaterialPoly
  • Surround MaterialSantoprene®
  • Magnet MaterialNeodymium
  • Overall Outside Diameter2.24"
  • Baffle Cutout Diameter2.05"
  • Depth1.25"
  • # Mounting Holes4
  • Sealed Volume0.03 ft.³
  • Sealed F3175 Hz
  • Vented Volume0.03 ft.³
  • Vented F395 Hz
  • BrandTang Band
  • ModelW2-1803S
  • Part Number264-885
  • UPC844632078958
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (4 Reviews)
  • Weight0.15 lbs.
View similar products to the Tang Band W2-1803S 2" Neodymium Poly Full Range Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
