Tang Band T1-1942SB Speaker Module 2-5/16" x 2-5/16"
Brand:|Model: T1-1942SB|Part # 264-934
Tang Band's T1-1942SB features a passive radiator-assisted 46 mm driver that plays from 75 to 20,000 Hz in a tiny 2.32" package. Design modern speakers never before thought possible.
List Price$48.99
You Save31%
Buy 4+$30.42
Part # 264-934
  • 46 mm polypropylene-composite inverted dome driver
  • Rear-mounted passive radiator extends response to 75 Hz
  • Tiny 2.32" self-contained design
  • Just add an amplifier for high-quality, full-range sound!
Tang Band's line of patented speaker modules are designed for modern audio applications such as sound bars, desktop multimedia speakers, flat panel TV speakers, and portable audio systems. Don't let Tang Band's diminutive driver modules fool you; each is built with a passive radiator that extends midbass frequency response, allowing these to mate to a subwoofer system quite easily.
The T1-1942SB speaker module is built around a passive radiator assisted, polypropylene composite 46 mm inverted dome driver. This allows for a very full frequency response from a single, small driver. Advantages of this type of speaker design include the elimination of crossover components in the critical midrange, superb off-axis response due to the use of a small driver (without hot spots), and perfect time-alignment.
Note: Tang Band recommends the use of a 2nd order (-12 dB/octave) 80 Hz high pass filter for the best possible sound. Higher power handling and output is possible by deploying multiple modules together.
  • Nominal Diameter2"
  • Power Handling (RMS)4 Watts
  • Power Handling (max)8 Watts
  • Impedance4 ohms
  • Frequency Response75 to 20,000 Hz
  • Sensitivity82 dB 1W/1m
  • Voice Coil Diameter1.10"
  • Resonant Frequency (Fs)75 Hz
  • Cone MaterialPoly Composite
  • Surround MaterialRubber
  • Basket / Frame MaterialPolymer
  • Magnet MaterialNeodymium
  • Overall Outside Diameter2.32" x 2.32"
  • Baffle Cutout Diameter2.20"
  • Depth1.72"
  • Bolt Circle Diameter2.6"
  • # Mounting Holes4
  • BrandTang Band
  • ModelT1-1942SB
  • Part Number264-934
  • UPC848864015118
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (1 Reviews)
  • Weight0.3500 lbs.
View similar products to the Tang Band T1-1942SB Speaker Module 2-5/16" x 2-5/16"
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
