264-934_ALT_0
264-934_ALT_1
Tang Band T1-1942SB Speaker Module
Brand:| Model: T1-1942SB
Tang Band's T1-1942SB features a passive radiator-assisted 46 mm driver that plays from 75 to 20,000 Hz in a tiny 2.32" package. Design modern speakers never before thought possible.
  • 46 mm polypropylene-composite inverted dome driver
  • Rear-mounted passive radiator extends response to 75 Hz
  • Tiny 2.32" self-contained design
  • Just add an amplifier for high-quality, full-range sound!
264-934
Weight: 0.3500 lbs.
IN STOCK
List Price$39.99
You Save15%
$33.80
Buy 4-up$30.42
Part # 264-934
Tang Band's line of patented speaker modules are designed for modern audio applications such as sound bars, desktop multimedia speakers, flat panel TV speakers, and portable audio systems. Don't let Tang Band's diminutive driver modules fool you; each is built with a passive radiator that extends midbass frequency response, allowing these to mate to a subwoofer system quite easily.
The T1-1942SB speaker module is built around a passive radiator assisted, polypropylene composite 46 mm inverted dome driver. This allows for a very full frequency response from a single, small driver. Advantages of this type of speaker design include the elimination of crossover components in the critical midrange, superb off-axis response due to the use of a small driver (without hot spots), and perfect time-alignment.
Note: Tang Band recommends the use of a 2nd order (-12 dB/octave) 80 Hz high pass filter for the best possible sound. Higher power handling and output is possible by deploying multiple modules together.
  • Nominal Diameter2"
  • Power Handling (RMS)4 Watts
  • Power Handling (max)8 Watts
  • Impedance4 ohms
  • Frequency Response75 to 20,000 Hz
  • Sensitivity82 dB 1W/1m
  • Voice Coil Diameter1.10"
  • Resonant Frequency (Fs)75 Hz
  • Cone MaterialPoly Composite
  • Surround MaterialRubber
  • Basket / Frame MaterialPolymer
  • Magnet MaterialNeodymium
  • Overall Outside Diameter2.32" x 2.32"
  • Baffle Cutout Diameter2.20"
  • Depth1.72"
  • Bolt Circle Diameter2.6"
  • # Mounting Holes4
  • BrandTang Band
  • ModelT1-1942SB
  • Part Number264-934
  • UPC848864015118
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
  • Weight0.3500 lbs.
View similar products to the Tang Band T1-1942SB Speaker Module
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
If I build 250Hz 2nd order high pass passive crossovers for a pair of these will they work well with a pair of 4 ohm 6.5" Dynaudio midbasses with a low pass(also 2nd order) passive network also set at 250Hz? How much power will they handle in this setup?
Asked by: AudioGman
There could be some issues with overall sensitivity between the drivers. This is a low 82 dB, so it will likely be overpowered by the woofer. It will be capable of more output if high passed at 250 Hz, but in order to work properly with that combination it would need to be bi-amped and actively crossed.
Date published: 2015-05-06
How loud  realisticly do you think this will play while installed as a stereo pair with your Kinter 310-380 amplifier while riding a Harley Davidson Dyna Wide Glide? I understand it will be lacking Bass:( Any information will help. WildBillMX
Asked by: WildBillMX
With the full 4 watts, this driver will only produce about 88 dB of total output. It is not the best choice for this type of application, the bike at idle probably produces more output than that. You need to be looking for a high sensitivity type driver, and the smallest you can really get away with is 3", 4" would be even better. It will be difficult to get any realistic bass from a setup like this. Two really good options for this type of thing would be from FaitalPRO below.http://www.parts-express.com/faitalpro-3fe25-3-professional-full-range-woofer-4-ohm--294-1103http://www.parts-express.com/faitalpro-4fe35-4-professional-full-range-woofer-4-ohm--294-1123
Date published: 2015-04-17
This may be a bit of a dumb question, but since all of the other TB modules seem to come in pairs, does this one as well?
Asked by: PGB1
These are sold individually.
Answered by: TomI
Date published: 2015-03-25
1. Would these work well with a HPF at about 350Hz in a system with a subwoofer? 2. Could this be used with a Peerless 830878 3-1/2" Passive Radiator?
Asked by: subs1313
Yes, but at 350 Hz porting or using a passive radiator will not matter. These already use a small passive on the back of the chamber, so they would not even need to have an enclosure.
Date published: 2015-01-30
where is the passive radiator? cant see it. front or back?
Asked by: arjunm009
The passive radiator is built into the back of this unit. It can be seen looking at the rear view on our website.
Date published: 2014-09-17
how can i power these with tpa3110 amp or do i have to use a 4w or 5w amp.
Asked by: arjunm009
These will work fine with that amplifier, there is no reason to use something smaller. As long as you know the limits of the speakers and keep them below those limits you will not have any problems.
  • 2015-07-06T08:01CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • co_hasquestionsanswers, tq_7
  • loc_en_US, sid_264-934, PRD, sort_recentQuestionsFirst
Customer projects that include: Tang Band T1-1942SB Speaker Module
