Tang Band T1-1931S Speaker Module Pair 3-1/2" x 1-7/16"
Brand:|Model: W1-1931S|Part # 264-931
Tang Band's T1-1931S features a passive radiator-assisted 31 mm driver that plays from 105 to 20,000 Hz in a tiny 4.25" x 1.42" package. Design modern speakers never before thought possible.
Now available in single units. See comparable item below.
Due In: 11/28/2016
List Price$49.99
You Save29%
Buy 4+$31.38
Part # 264-931
  • 31 mm polypropylene-composite inverted dome driver
  • Small, oval passive radiator extends response to below 200 Hz
  • Tiny 4.25" H x 1.42" W x 0.76" D self-contained design
Tang Band's line of patented speaker modules are designed for modern audio applications such as sound bars, desktop multimedia speakers, flat panel tv speakers, and portable audio systems. Don't let Tang Band's diminutive driver modules fool you; each is built with a passive radiator that extends midbass frequency response, allowing these to mate to a subwoofer system quite easily.
The T1-1931S speaker module is the smallest of the three speaker modules from Tang Band and is built around a passive radiator assisted, polypropylene composite 31 mm inverted dome driver. This allows for a very full frequency response from a single, small driver. Advantages of this type of speaker design include the elimination of crossover components in the critical midrange, superb off-axis response due to the use of a small driver (without hot spots), and perfect time-alignment.
Tang Band incorporated mounting tabs and a two-pin wiring harness jack into the T1-1931S to facilitate mounting and amplifier connection to the optional KIT-0041 speaker module mounting kit with amplifier. For custom applications, two polarity-indicated solder points are built onto the driver PCB. Sold in pairs.
Note: Tang Band recommends the use of a 2nd order (-12 dB/octave) 100 Hz high pass filter for the best possible sound. Higher power handling and output is possible through the use of multiple modules.
  • Nominal Diameter1" x 5"
  • Power Handling (RMS)2 Watts
  • Power Handling (max)4 Watts
  • Impedance4 ohms
  • Frequency Response105 to 20,000 Hz
  • Sensitivity76 dB 1W/1m
  • Voice Coil Diameter0.79"
  • Resonant Frequency (Fs)105 Hz
  • Cone MaterialPoly Composite
  • Surround MaterialRubber
  • Basket / Frame MaterialPolymer
  • Magnet MaterialNeodymium
  • Overall Outside Diameter3.46" x 1.41"; With mounting tabs: 4.25"
  • Depth0.76"
  • # Mounting Holes4
  • BrandTang Band
  • ModelW1-1931S
  • Part Number264-931
  • UPC848864003016
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
  • Unit of MeasurePR
    (1 Reviews)
  • Weight0.3000 lbs.
View similar products to the Tang Band T1-1931S Speaker Module Pair 3-1/2" x 1-7/16"
in the Speaker Modules product category.
