Tang Band T1-1828S Speaker Module Pair
Brand:|Model: W1-1828SA
The T1-1828S speaker module from Tang Band makes modern speaker designing a breeze. An aluminum 46 mm inverted dome driver is mated to a passive radiator and mounted in a polypropylene enclosure for a simple, small fullrange speaker solution.
$46.62
Buy 4+$39.90
Part # 264-930
  • 46 mm aluminum-composite inverted dome driver
  • Wide band response through the use of a passive radiator
  • Self-contained 6.06" H x 2.13" W x 0.92" D design
  • Great for nearfield listening
Tang Band's line of patented speaker modules are designed for modern audio applications such as sound bars, desktop multimedia speakers, flat panel tv speakers, and portable audio systems where small size is of utmost importance. Don't let Tang Band's diminutive driver modules fool you; each is built with a passive radiator that extends midbass frequency response, allowing these to mate to a subwoofer system quite easily.
The T1-1828S speaker module is built around a passive radiator assisted, aluminum composite 46 mm inverted dome driver. This allows for a very full frequency response from a single, small driver. Advantages of this type of speaker design include the elimination of crossover components in the critical midrange, superb off-axis response due to the use of a small driver (without hot spots), and perfect time-alignment.
Tang Band incorporated mounting tabs and a two-pin wiring harness jack into the T1-1828S to facilitate mounting and amplifier connection to the optional KIT-0041 speaker module mounting kit with amplifier. For custom applications, two polarity-indicated solder points are built onto the driver PCB. Sold in pairs.
Note: Tang Band recommends the use of a 2nd order (-12 dB/octave) 80 Hz high pass filter for the best possible sound. Higher power handling and output (SPL) is possible through the use of multiple modules.
  • Nominal Diameter2-1/4" x 6-1/4"
  • Power Handling (RMS)4 Watts
  • Power Handling (max)8 Watts
  • Impedance4 ohms
  • Frequency Response78 to 20,000 Hz
  • Sensitivity80 dB 1W/1m
  • Voice Coil Diameter1.1"
  • Resonant Frequency (Fs)78 Hz
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Basket / Frame MaterialPolymer
  • Overall Outside Diameter2.13" x 6.06"
  • Depth0.92"
  • BrandTang Band
  • ModelW1-1828SA
  • Part Number264-930
  • UPC848864003009
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
  • Unit of MeasurePR
  • Weight0.7500 lbs.
View similar products to the Tang Band T1-1828S Speaker Module Pair
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
how will these and tang bands 5-1/4" subwoofer get along?
Asked by: speakerfreack
As long as the subwoofer is self amplified and these are high passed around 150 Hz they should work well together for low-medium volume levels.
Date published: 2014-02-03
TB recommends a 2nd order 80 hz high pass xover is there a preassembled unit or a schematic that i can build from thanks Crash
Asked by: Crashradius
We do offer an 80 Hz high pass filter that will work with these, you can see it below.
Date published: 2013-04-10
  • 2015-08-04T08:12CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • loc_en_US, sid_264-930, PRD, sort_recentQuestionsFirst
