Tang Band T0-2008S Speaker Module Pair
Brand:|Model: T0-2008S|Part # 264-928
Tang Band's T0-2008S features a passive radiator-assisted 20.1 mm driver that plays from 200 to 20,000 Hz in a tiny 2.17" by 0.94" package. Design modern speakers never before thought possible.
List Price$39.99
You Save28%
$28.60
Buy 4+$25.74
Part # 264-928
  • 20.1 mm polypropylene-composite inverted dome driver
  • Small, oval passive radiator extends response to 200 Hz
  • Tiny 2.17" H x 0.94" W x 0.34" D self-contained design
Tang Band's line of patented speaker modules are designed for modern audio applications such as sound bars, desktop multimedia speakers, flat panel tv speakers, and portable audio systems. Don't let Tang Band's diminutive driver modules fool you; each is built with a passive radiator that extends midbass frequency response, allowing these to mate to a subwoofer system quite easily.
The T0-2008S speaker module is the smallest of the three speaker modules from Tang Band and is built around a passive radiator assisted, polypropylene composite 20.1 mm inverted dome driver. This allows for a very full frequency response from a single, small driver. Advantages of this type of speaker design include the elimination of crossover components in the critical midrange, superb off-axis response due to the use of a small driver (without hot spots), and perfect time-alignment. Sold in pairs.
Note: Tang Band recommends the use of a 2nd order (-12 dB/octave) 180 Hz high pass filter for the best possible sound. Higher power handling and output is possible by deploying multiple modules together. The T0-2008S is not designed to work with Tang Band's KIT-0041 speaker module mounting kit with amplifier.
  • Nominal Diameter1" x 2"
  • Power Handling (RMS)0.50 Watts
  • Power Handling (max)1 Watts
  • Impedance4 ohms
  • Frequency Response200 to 20,000 Hz
  • Sensitivity73 dB 1W/1m
  • Resonant Frequency (Fs)200 Hz
  • Cone MaterialPoly Composite
  • Surround MaterialRubber
  • Basket / Frame MaterialPolymer
  • Magnet MaterialNeodymium
  • Overall Outside Diameter0.94" x 2.17"
  • Depth0.34"
  • # Mounting Holes2
  • BrandTang Band
  • ModelT0-2008S
  • Part Number264-928
  • UPC848864015095
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
  • Weight0.0254 lbs.
