Tang Band 28-847SD Shielded Neodymium Dome Tweeter
Brand:|Model: 28-847SD|Part # 264-822
The neodymium motor structure and damped rear chamber give this tweeter performance that can rival many of the expensive drive units on the market. A low Fs, well-damped 1-1/8" dome, and tuned rear chamber produce well-behaved performance for all occasions.
List Price$35.31
You Save23%
$27.16
Buy 4+$25.80
Part # 264-822
  • Large damped rear chamber keeps Fs low for a tweeter this small
  • Ferrofluid in the magnetic gap improves power handling and damping
  • Compact 2-7/8" diameter faceplate is ideal for use in MTM arrangements
  • Powerful neodymium motor for precise control and small size
The neodymium motor structure and damped rear chamber give this tweeter performance that can rival many of the expensive drive units on the market. A low Fs, well-damped 1-1/8" dome, and tuned rear chamber produce well-behaved performance for all occasions. The small mounting flange is sure to make this a popular tweeter for MTM designs. Neodymium motor allows close placement to CRT based monitors.
  • Tweeter TypeSoft Dome
  • Cone / Dome Diameter1"
  • Impedance8 ohms
  • Power Handling (RMS)80 Watts
  • Frequency Response850 to 20,000 Hz
  • Sensitivity90 dB 1W/1m
  • Resonant Frequency (Fs)850 Hz
  • DC Resistance (Re)6.00 ohms
  • Voice Coil Inductance (Le)0.01 mH
  • Overall Outside Diameter2.83"
  • Cutout Diameter1.89"
  • Depth1.78"
  • BrandTang Band
  • Model28-847SD
  • Part Number264-822
  • UPC844632019487
  • Product CategoryTweeters
    (22 Reviews)
  • Weight0.75 lbs.
View similar products to the Tang Band 28-847SD Shielded Neodymium Dome Tweeter
in the Tweeters product category.
Tang Band 28-847SD Shielded Neodymium Dome Tweeter is rated 4.3182 out of 5 by 22.
Rated 5 out of 5 by from Great buy for the money!!I recently purchased a pair of these for my first DIY project, and couldn't be happier!! I'm not a professional by any means, so you can't take my words to seriously!! To me these tweeters sound great, crossed over at 2,500khz they are very clear and detailed. I let a close friend of mine who built speakers for a living test them out and he gave me a thumbs up!! I wanted a vintage look and parts express had everything I needed, I paired them with Visaton WS-17E 6.5" Driver, and Dayton Audio's 2 way crossover. Super pleased with the end results!! Thanks Parts Express!!
Date published: 2015-08-15
Rated 5 out of 5 by from ImpressiveI installed these in two way cabinets (12db/octave @1200Hz) and was very impressed with their clean uncolored sound. They easily go to the top of my hearing range (18kHz) without getting harsh and handle all the power I will ever throw at them without strain. They may be plastic but that subtracts zero from performance or appearance in the cabinet.
Date published: 2014-12-28
Rated 5 out of 5 by from Nailed it!!I wanted a natural and realistic sounding low distortion tweeter to use in my pictured 3 way paper woofers speaker design and that is what I got. I like it so much that at $27, it might be hard to try a different one on my next project.
Date published: 2014-07-21
Rated 2 out of 5 by from Good design/ Cheaply made.I used this in a 2way .23 box matches with the Dayton RS180P 8. The sound is OK in the lower Frequencies but at the very top it is a little harsh and tiring to listen to. Voices are good and are reproduced nice, music is decent but not great. All in all it ok for the price but NOT great by any means!
Date published: 2014-06-24
Rated 4 out of 5 by from GOOD SOUNDI BOUGHT THESE TWEETERS TO REPLACE THE 70740 TITANIUM JBL TWEETER, THEY MATCH WELL WITH THE SPEAKERS YOU MAY THINK THEY SOUND LIKE THE ORIGINAL, MY REVIEW IS LOW TO MED VOLUME THEY STAY CLEAR AND A TOUCH OF CRISP, LOW VOLUME WILL COME LATER
Date published: 2014-05-14
Rated 4 out of 5 by from Great sound.I auditioned this great sounding tweeter in a 2-way rebuild and found it to be clear and crisp throughout it's range. Due to it's size I was unable to use it but I know it's a great sounding tweeter and I'll keep it in mind for a future build.
Date published: 2014-05-01
  • 2016-02-08T06:27CST
  • co_hasreviews, tv_0, tr_22
  • loc_en_US, sid_264-822, PRD, sort_mostRecent
Is this a good replacement tweeter for a infinity primus p363 ?
Asked by: Ricky710
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-12-21
If I use 2 of these with 2 Dayton Audio ND65-8 2 1/2" woofers in a 2-way design, what would the recommended crossover frequency be? Thanks
Asked by: Mjleja
With those woofers any crossover frequency from 2kHz and up would work. Since those ND65's are so flat, I would probably cross these around 5kHz.
I am wondering how low of a crossover point I could use with a third order and maybe even adding a notch filter. What has been users experience?
Asked by: fdrahuse
I would recommend a crossover no lower than about 1,800 Hz for this tweeter using a third order filter.
Date published: 2014-11-20
Resonance Free Air is different from spec sheet. Which one is correct?
Asked by: BCM90
The spec sheet is accurate with this information. I will have the website updated.
Date published: 2014-09-18
Is this a good replacement tweeter for Technics SB-TA310 (technics part # EAST25KH10A6)?
Asked by: Adrie
Unfortunately we do not have a cross reference available for this type of thing. As long as the impedance matches and physical dimensions are similar or the cabinet can be modified it should work fine.
Date published: 2014-06-12
What is the difference between the -847SD (displayed) and the -847SE (product page displayed)?
Asked by: Perkins
These tweeters are identicle with the exception of the trip rim color. The SE model had a silver trim ring and has been discontinued. The SD is all black and is still available. They are interchangeable.
Date published: 2015-09-09
  • 2016-02-08T07:19CST
  • co_hasquestionsanswers, tq_8
  • loc_en_US, sid_264-822, PRD, sort_recentQuestionsFirst
