Tang Band 25-302SH 1" Shielded Neodymium Dome Tweeter
Brand:|Model: 25-302SH|Part # 264-804
This small tweeter utilizes a soft fabric dome and slightly horn-loaded flange, resulting in an extremely flat and extended frequency response.
List Price$27.51
You Save23%
$21.16
Buy 4+$20.10
Part # 264-804
  • Exceptionally smooth response from 2,000 to 20,000 Hz
  • Semi-horn loaded design controls dispersion while improving efficiency
  • Ferrofluid and pole damping lowers Fs and eliminates resonant peaks
  • Truncated faceplate allows closer center-to-center spacing, perfect for MTM designs
This small tweeter utilizes a soft fabric dome and slightly horn-loaded flange, resulting in an extremely flat and extended frequency response. Despite the small size, it has good power handling thanks to its ferrofluid cooled shielded neodymium motor structure. The truncated flange allows for close spacing of drivers, especially important in MTM designs.
  • Tweeter TypeSoft Dome
  • Cone / Dome Diameter1"
  • Impedance8 ohms
  • Power Handling (RMS)40 Watts
  • Frequency Response1,400 to 20,000 Hz
  • Sensitivity91 dB 1W/1m
  • Resonant Frequency (Fs)1,400 Hz
  • DC Resistance (Re)6.00 ohms
  • Overall Outside Diameter2.75" x 2.13"
  • Cutout Diameter1.61"
  • Depth0.98"
  • BrandTang Band
  • Model25-302SH
  • Part Number264-804
  • UPC844632019371
  • Product CategoryTweeters
    (37 Reviews)
  • Weight0.2 lbs.
View similar products to the Tang Band 25-302SH 1" Shielded Neodymium Dome Tweeter
in the Tweeters product category.
Tang Band 25-302SH 1" Shielded Neodymium Dome Tweeter is rated 4.6757 out of 5 by 37.
Rated 4 out of 5 by from Good valueI had one burn out and need a replacement. I replaced them in pairs so they would break in at the same time.Very nice for a ferro fluid dampened tweeter. I belive I would have to spend almost 3 times as much to get an obviously superior tweeter. What made a dramtic difference was the Nobel circuit I used on the peerless 6" Al. woofer.See my review of the Dayton caps I bought.
Date published: 2015-04-27
Rated 5 out of 5 by from Good replacement for ascend cbm-170With minor mod (small drill bit to increase opening) , fits well in ascend cbm-170 bookshelf speakers. Sounds great!
Date published: 2014-09-21
Rated 5 out of 5 by from Needed one for a Polk Audio R1 retrofit.So I had one of these in a Center Channel Project that I have since stopped using some years now and it worked well there...Fast forward a bit to present day, was playing my Polk Audio R1 and found that the tweeters on both had taken a dump. So I decided to salvage the tweeter and get another. Had to do some fabricating from the old tweeters to get the plate that held it down, some glue and presto. Only thing the crossover for the OEM Tweeters seemed to have been crossed a bit low so lots of mids come through but the Tang Bands are not doing half bad. I think they sound better than before just for casual listening actually. Worth it indeed.
Date published: 2014-04-14
Rated 5 out of 5 by from Good value with great soundI have these paired with dayton's 5" (designer series), crossed around 3.2khz. Playing from bluegrass to edm these tweeters keep up. Definitely a smooth airy sound with a bit of a hollow sound at the top of the range. There's even some sparkle but expectantly limited to a <$30 tweeter. "It's rated at 5 stars for it's value.
Date published: 2014-04-11
Rated 5 out of 5 by from great soundbought these to replace the tweeters in my polk audio monitor 40s....sound great!!!
Date published: 2014-02-26
Rated 4 out of 5 by from Nice TweeterI put the Tang Band tweeter in a pair of PE Knock Down Micro Speakers to get a little more highs in my system. The result was worth it and now I can really hear the cymbals! They are easy to install and worth the money.
Date published: 2013-11-25
  • 2016-02-08T06:26CST
  • co_hasreviews, tv_0, tr_37
  • loc_en_US, sid_264-804, PRD, sort_mostRecent
Can I, using active 4th order filtering, XO these @ 2K or lower?
Asked by: 975 Destroyer
I would not recommend crossing these lower than 2,500 fourth order.
Date published: 2016-01-13
Do you know if Tweeter part #25-302SH 1" Tang Band Dome Tweeter will fit right into the Polk Audio Monitor 70 Series II speakers?
Asked by: Scott Clark
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-11-11
Thinking of 2nd order high-pass at 2.5K. Okay for these? Also, would like to confirm that these have a nice wide dispersion? They are going to be used in OB.
Asked by: ibrokeit
I would recommend bumping that crossover to 3k. These will have a very wide dispersion.
Date published: 2015-09-10
I've noticed that these types of tweeters gather dust very easily because the silk dome is quite sticky....  How would you clean the silk dome?  And what would you use?
Asked by: eibwen lufepoh
Answered by: GregT
Date published: 2015-05-27
I purchased two of these hoping to put them in parrellel to a parts express 4 ohm highpass 5k crossover.  When in use i first tried them both to the crossover and near 70% power there was a hickup in the music every second.  What is causing it?
Date published: 2015-04-22
Do they come in pair?
Asked by: luisdr1
These are sold individually.
Date published: 2014-09-25
  • 2016-02-08T07:19CST
  • co_hasquestionsanswers, tq_11
  • loc_en_US, sid_264-804, PRD, sort_recentQuestionsFirst
