Talos Security SP1245 CCTV 12 VDC Switching Power Supply Adapter 4-Output for Camera
Brand:|Model: SP1245|Part # 334-117
A Talos switching power supply guarantees continuous, reliable, single-source operation of up to four CCTV cameras.
List Price$25.99
You Save25%
$19.50
Buy 2+$18.53
Part # 334-117
  • Operate multiple cameras from a single, ultra-efficient power supply
  • High current capacity prevents voltage drop over long runs
  • Four 12 VDC outputs
  • Male 2.1 mm x 5.5 mm DC power plugs
  • World power compatible
Ample power is necessary for proper operation of CCTV cameras. This CCTV power supply features high current capacity to provide steady voltage, which compensates for voltage drop across long distance power cables. The built-in switch mode power supply is extremely efficient, resulting in a power solution that is small and light. Four individual output leads with DC male power plugs make this power supply ideal for small systems with up to four cameras.
Specifications: • Input voltage: 100 to 240 VAC, 50/60 Hz, 1.5A • Output voltage: 12 VDC, 5A • Output plugs: Male 2.1 mm x 5.5 mm, center positive • Power cord length: 48" • Lead length: 18".
  • DC Output Voltage12V
  • Current Capacity1500 mA
  • Center/Tip PolarityCenter (+)
  • Plug Size2.1 x 5.5 mm
  • Input Voltage100~240 VAC
  • BrandTalos Security
  • ModelSP1245
  • Part Number334-117
  • UPC844632093807
  • Product CategoryAC/DC Power Adapters
    (2 Reviews)
  • Weight0.5 lbs.
View similar products to the Talos Security SP1245 CCTV 12 VDC Switching Power Supply Adapter 4-Output for Camera
in the AC/DC Power Adapters product category.
Talos Security SP1245 CCTV 12 VDC Switching Power Supply Adapter 4-Output for Camera is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from Good servicesFast shipping and very good products, you have a very good services
Date published: 2013-05-10
Rated 5 out of 5 by from Convenient, space saving design relieves a lot of hasslesThis makes connecting four cameras a neat and easy proposition. It is simply a basic 12v switching device that supports four camera power inputs. It will also support other devices. I have used it to also power a wireless router and a wireless access point (WAP). As long as your devices run at 12v, support the common connection, and don't pull more than a total of 4 amps, I believe you could use this with just about any compatible device.Also, since some cameras come with power supplies and others don't, you may save some money by purchasing cameras that don't include a power supply.This device is a boon for those who want neat, professional looking results. It sure beats connecting 4 "wall warts" to a power strip.Recommended.
Date published: 2011-11-26
  • 2016-05-02T06:20CST
  • bvseo_cps, prod_bvrr, vn_cps_3.2.0
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_334-117, PRD, sort_mostRecent
Will a single output connector provide the full 5 amps output if it is the only connection or would I have to clip the pig tail and put a connector on the 2 main + and - ouput leads?
Asked by: Stevedrivr
The power is evenly distributed between whichever outputs are being used. If you only use one pigtail, all 5 amps will be available to that device.
Date published: 2015-12-02
Can I use this for 4 strings of LED lights? The package says 100 LED .06A @ 12V? It didn't come with any power adapters so I'm trying to figure out how I can use them without buying a separate adapter for each!?
Asked by: Kayla
Is this power supply regulated?
And ... Will this power supply power two of these amplifiers simultaneously?
Asked by: Immanuel
This power supply is regulated. Which amplifiers are you referring to?
Can this be used with the Lepai LP-2020A+?
Asked by: TripleR008
Yes this will work with that amplifier.
  • 2016-05-02T06:41CST
  • bvseo_cps, prod_bvqa, vn_cps_3.2.0
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_334-117, PRD, sort_recentQuestionsFirst
