334-150_ALT_0
334-150_ALT_1
334-150_ALT_2
Talos Security PTZ100 In/Outdoor Pan Tilt Zoom (PTZ) Dome Camera 420 Line 4-9mm Lens
Brand:|Model: PTZ100|Part # 334-150
The Talos Indoor/Outdoor Pan Tilt Zoom (PTZ) Dome Color Camera is compact and versatile; the camera's wide range of coverage is matched by its ability to withstand weather and abuse.
Part # 334-150
  • Pan, tilt, and zoom for complete subject focus
  • 4-1/2" diameter and 5" high
  • RS485 serial control compatible with Pelco D/P protocol
  • Heavy-duty white aluminum housing
  • Works well in dimly lit areas with a 0.5 minimum lux requirement
Expand your view of the world with a Talos Pan Tilt Zoom (PTZ) camera. This PTZ color camera can pan 360°, tilt 90°, and features a lens that is  4 mm to 9 mm adjustable (equivalent to a 2.25x optical zoom, much better than other companies' digital zoom) to follow subjects or change your observation area as you desire.
Measuring 4-1/2" diameter and 5" high, this PTZ camera will not draw undue attention to itself. RS485 serial control and Pelco D/P protocol allow you to easily integrate this camera into a compatible surveillance system. The white heavy-duty aluminum housing protects the sensitive camera inside from daily hazards and harsh environments.
Specifications: • Image device: 1/3" Sony Color CCD • Resolution: 420 lines • Picture elements: 510 x 492 • Minimum illumination: 0.5 lux • Internal synchronization • White balance: Auto • Gain control: Auto • Electronic shutter: 1/20,000 • Lens: 4 mm to 9 mm zoom lens • Automatic iris control • Video output: 1V p-p, 75 ohms via BNC female connector • Power: 12VDC, 450 mA via a 5.5 mm x 2.1 mm jack (power supply sold separately) • Dimensions: 4-1/2" dia. x 5" H • Weight: 2.2 lbs.
  • Camera TypeDome
  • Special FeaturesIndoor/Outdoor,PTZ (Pan Tilt Zoom)
  • Operating Voltage12 VDC
  • Resolution420 TVL
  • BrandTalos Security
  • ModelPTZ100
  • Part Number334-150
  • UPC844632093784
  • Product CategorySurveillance Cameras
    (1 Reviews)
  • Weight1.8 lbs.
View similar products to the Talos Security PTZ100 In/Outdoor Pan Tilt Zoom (PTZ) Dome Camera 420 Line 4-9mm Lens
in the Surveillance Cameras product category.
