Talos Security DVM620F Mini Vandal Dome Camera 3-Axis 620TVL 3.6mm Lens 12VDC
Brand:|Model: DVM620F|Part # 334-384
The Talos DVM620F mini dome camera features excellent durability, along with compactness that fits in tight spaces where bulkier cameras cannot.
Comparable Items In Stock:
Part # 334-384
  • Accurate 1/3" Sony Super HAD CCD 3.6 mm lens with 620TV lines of resolution
  • IP66 environmental rating denotes certified weather resistance
  • 3-year limited manufacturer's warranty
  • High sensitivity, even at ultra-low light levels of 0.01 lux
  • Easy installation with 3-Axis gimbaled bracket
  • Vandal-resistant solid aluminum housing
Engineered for minimal size combined with resistance to vandalism and weather, the Talos DVM620F mini dome camera's rugged, heavy duty housing is precision-machined from solid aluminum. The upper and lower housings interlock, and feature an o-ring to help prevent moisture and dirt from entering the camera.
The camera housing's shape is designed specifically to make it difficult to grasp and almost impossible to pull off a wall or ceiling. Installation can be inside or outside (should be located out of direct rain). Onboard is a 1/3" Sony Super HAD CCD 3.6 mm lens with 620TV lines of resolution, for sharp, easily discernable images. An electronic shutter adjusts automatically to keep the image consistent as lighting conditions change.
Specifications: • Camera style: Dome • Image device: 1/3" Sony Super HAD CCD • Lighting level control: Electronic shutter • Lens: 3.6 mm • Power requirement: 12 VDC • Environmental rating: IP66 (weather resistant) • Dimensions: 3.64" x 2.46" x 2.36" (92.5 x 62.5 x 60 mm) • Weight: 1.00 lbs. (450 g).
  • Camera TypeDome
  • Special FeaturesIndoor/Outdoor,Mini Style,Vandal Proof
  • Operating Voltage12 VDC
  • Resolution620 TVL
  • Commercial GradeYes
  • BrandTalos Security
  • ModelDVM620F
  • Part Number334-384
  • UPC848864004532
  • Product CategorySurveillance Cameras
  • Weight1 lbs.
View similar products to the Talos Security DVM620F Mini Vandal Dome Camera 3-Axis 620TVL 3.6mm Lens 12VDC
in the Surveillance Cameras product category.
