Talos Security DV700VTIR Vandal Resist IR Dome Camera 3-Axis 700TVL 2.8-12mm Lens 24VAC/12VDC IP67
Brand:|Model: DV700VTIR|Part # 334-400
An advanced asset for IP67-rated indoor/outdoor surveillance use, the Talos DV700VTIR vandal-resistant dome camera provides clear, accurate video images, regardless of lighting levels.
Comparable Items In Stock:
  • Rugged housing that's also rated for outdoor use
  • 1/3" SONY Super HAD II CCD with 470K pixels
  • 3-year limited manufacturer's warranty
  • 700TV lines (Color) for superior resolution
  • Super Digital Noise Reduction Technology (SDNR)
  • Defog function and Auto IR Brightness Control (ABC)
  • Dual voltage (24 VAC/12 VDC) expands power options
The Talos DV700VTIR indoor/outdoor vandal resistant dome camera features a nearly indestructible enclosure, great day or night video capture, and enhanced mounting and setup. Its Sony 1/3" sensor, powerful G7+ DSP chipset, and 2.8 ~ 12 mm varifocal lens with auto iris pull in all of the action.
Onboard IR illumination renders great images when ambient lighting levels are low, and the automatic brightness control compensates for all other conditions. A 3-Axis mount and service monitor output expedite installation and surveillance system setup.
Specifications: • Camera style: Dome • Minimum illumination: 0 lux • White balance: Switchable • Gain control: Switchable • BLC: Switchable • Lighting level control: DC automatic iris • Environmental rating: IP67 • Power requirement: 12 VDC / 24 VAC dual voltage • Dimensions: 5.35" x 4.37" ø3.94" (136 x 111 mm ø100 mm) • Weight: 1.9 lbs. (875 g).
  • Camera TypeDome
  • Special FeaturesIR Illumination,Indoor/Outdoor,Vandal Proof,Varifocal Lens
  • Operating Voltage12 VDC/24 VAC
  • Resolution700 TVL
  • Commercial GradeYes
  • BrandTalos Security
  • ModelDV700VTIR
  • Part Number334-400
  • UPC848864004617
  • Product CategorySurveillance Cameras
  • Weight2.5 lbs.
View similar products to the Talos Security DV700VTIR Vandal Resist IR Dome Camera 3-Axis 700TVL 2.8-12mm Lens 24VAC/12VDC IP67
in the Surveillance Cameras product category.
