Talos Security DV700V Vandal Dome 3-Axis 700TVL 2.8-12mm Lens 24VAC/12VDC IP67
Brand:|Model: DV700V|Part # 334-386
A Talos DV700V vandal-proof indoor/outdoor dome camera with 0.01 lux offers immunity from adverse conditions and events, and includes many operational and installation-friendly features.
Part # 334-386
  • Industry-standard 1/3" SONY Super HAD II CCD image device
  • Built-in 2.8 ~ 12 mm varifocal lens with auto iris produces crisp, clear output
  • 3-year limited manufacturer's warranty
  • 700TV lines color resolution delivers accurate rendering
  • Minimum illumination 0.01 lux @ F1.2 (B/W) for great low-light images
  • Defog function / D-WDR function
  • Dual voltage (24 VAC/12 VDC) expands power options
Vandal-proof dome cameras are designed to withstand abuse and harsh environments. The Talos DV700V high-resolution dome camera's rugged, heavy duty aluminum die-cast housing incorporates rubber O-ring seals for protection against dust and moisture ingress. This dome housing was designed with the professional installer in mind: easy access to mounting holes, and a tether that holds the upper dome while camera adjustments are made, make installations smoother. Additionally, captive screws are used to secure the upper and lower dome housing.
The DV700V features an enhanced powerful G7+ DSP chipset, 700TVL color resolution, 3-Axis mount, service monitor output, an IP67 environmental rating, varifocal 2.8-12 mm lens, and dual voltage options, making this professional security camera a capable and flexible tool for installers and property owners.
Specifications: • Camera style: Dome • Image device: 1/3" Sony Super HAD CCD • White balance: Switchable • Gain control: Switchable • BLC: Switchable • Lighting level control: DC automatic iris • Power requirement: 12 VDC / 24 VAC dual voltage • Environmental rating: IP67 (weatherproof) • Dimensions: 5.35" x 4.37" ø3.94" (136 x 111 mm ø100 mm) • Weight: 1.9 lbs. (875 g).
  • Camera TypeDome
  • Special FeaturesIndoor/Outdoor,Vandal Proof,Varifocal Lens
  • Operating Voltage12 VDC/24 VAC
  • Resolution700 TVL
  • Commercial GradeYes
  • BrandTalos Security
  • ModelDV700V
  • Part Number334-386
  • UPC848864004549
  • Product CategorySurveillance Cameras
  • Weight2.5 lbs.
View similar products to the Talos Security DV700V Vandal Dome 3-Axis 700TVL 2.8-12mm Lens 24VAC/12VDC IP67
in the Surveillance Cameras product category.
