CLEARANCE
334-358_ALT_0
334-358_ALT_1
334-358_ALT_2
Talos Security DV1080VIR24 HD-SDI 1080p Vandal IR Dome Camera 2.8-12mm Lens 24VAC/12VDC
Brand:|Model: DV1080VIR24|Part # 334-358
A Talos DV1080VIR24 dome camera fills the need for a high-resolution, weatherproof, and tamperproof video source.
List Price$380.00
You Save29%
$268.00
Buy 5+$254.60
Part # 334-358
  • Withstands adverse weather conditions and attempted vandalism
  • 1/3" CMOS 2.1 Megapixel sensor and 16:9 HD (1080p) resolution support
  • 30 FPS at Full HD (1080p) resolution offers great image quality
  • WDR (Wide Dynamic Range) provides greater contrast and clarity, day or night
  • Integrated IR system provides full capture, regardless of light conditions
  • Upgrades surveillance systems to HD-SDI, without reinstalling wire
  • Dual voltage (24 VAC/12 VDC) expands power options
The Talos DV1080VIR24 HD-CCTV vandal-proof indoor/outdoor camera's 3DNR (3-Dimensional Digital Noise Reduction) function removes video noise in dark environments, which provides clear images as a result. The TDN (True Day & Night) function always delivers coherent video images by distinguishing between daytime and nighttime. At night, the TDN mechanism removes the IR-Cut filter to gather more light.
For easy installation, the Talos DV1080VIR24 camera is equipped with an auxiliary CVBS (NTSC/PAL) video output. By using the CVBS output's full-screen and zoom-screen options, an installer can adjust the angle of view and focus. This also includes infra-red light sources as well. The Wide Dynamic Range (WDR) feature enables the capture and display of light and dark areas in the same frame, resulting in enhanced details in both areas. For example, bright areas are not too saturated, and dark areas are not overly dark. The Talos DV1080VIR24 is suitable for indoor and outdoor environments.
HD-SDI stands for High Definition Serial Digital Interface, in compliance to standards developed by the Society of Motion Picture and Television Engineers (SMPTE). This allows bit rates of 1.485 Gbit/s (aka SMPTE 292M), which is used for HDTV production and broadcasting in 720P and 1080p resolutions. HD-SDI video's interconnectivity is based on inexpensive and readily available RG59 coaxial cable.
Specifications: • Camera style: Dome • Image device: 1/3" Sony CMOS 2.1 megapixel • Minimum illumination: 0 lux • Power requirement: 12 VDC/ 24 VDC • Environmental rating: IP67 • Dimensions: 5.67" x 4.21" ø3.94" (144 x 107 mm, ø100 mm) • Weight: 2.9 lbs. (1300 g).
  • Camera TypeDome
  • Special FeaturesHD-SDI 1080p (Full-HD),IR Illumination,Indoor/Outdoor,Vandal Proof,Varifocal Lens
  • Operating Voltage12 VDC/24 VAC
  • Resolution1080TVL;
  • BrandTalos Security
  • ModelDV1080VIR24
  • Part Number334-358
  • UPC848864004396
  • Product CategorySurveillance Cameras
  • Weight2.5 lbs.
View similar products to the Talos Security DV1080VIR24 HD-SDI 1080p Vandal IR Dome Camera 2.8-12mm Lens 24VAC/12VDC
in the Surveillance Cameras product category.
Videos
