Talos Security DRSDI8414 8-Channel HD-SDI DVR 240 FPS 4TB HDD DVDRW
Brand:|Model: DRSDI8414|Part # 334-272
The DRSDI Series from Talos Security allows you to use existing or new coax cable to transmit HD video from their full line of HD-SDI cameras and record them. The built-in DVD-RW makes archiving easy.
Part # 334-272
  • 8-Channel DVR with 4TB HDD
  • Upgrade to HD security system with existing cables
  • Pentaplex operating mode
  • Built-in DVD-RW for easy archiving
  • Viewer software for smartphone (iPhone/Android)
  • 3 year warranty
Talos Security DRSDI841 gives you 8 channels of High Definition 1080p Video and 8 channels of Audio in one feature rich and easy to use DVR. The digital signal travels over 75 Ohm Coaxial or Fiber Optic cable, this is ideal for upgrading analog camera systems or long distance transmission video solutions over fiber.
The easy to use interface via USB mouse, IR remote, or front panel controls allows for quick and easy setup, playback, and data backup. The DRS Series offers top of the line quality, reliability and performance. Combined with a 3 year warranty all of this adds up to a value that is unmatched in the market today!
Specifications: • Video compression: H.264 • Inputs: Video: 8 HD-SDI; Audio: 8 • Outputs: HDMI, SDI, VGA; Audio: 1 RCA • Video display rate: Real time • Video display resolution: 1920 x 1080 • Video record rate: 240 FPS 1080p (1920 x 1080) • Operating mode: Pentaplex • Storage: 4TB SATA HDD • USB: Yes (2) • Ethernet: Gigabit • Alarm I/O: 16-In, 2-Out • PTZ: Yes • Power requirements: 100~220 VAC, 50~60 Hz • Dimensions: 3.46" H x 16.93" W x 17.44" D (88 x 430 x 443 mm).
  • TypeHD-SDI / Hybrid HD-SDI
  • Input Channels8
  • Hard Drive Capacity4TB
  • BrandTalos Security
  • ModelDRSDI8414
  • Part Number334-272
  • UPC848864013749
  • Product CategorySurveillance DVRs
  • Weight21.3500 lbs.
View similar products to the Talos Security DRSDI8414 8-Channel HD-SDI DVR 240 FPS 4TB HDD DVDRW
in the Surveillance DVRs product category.
