Talos Security DRL800 8-Channel H.264 DVR D1 120 FPS No HDD
Brand:|Model: DRL800|Part # 334-3125
The Talos Security DRL800 8-channel commercial compact DVR system provides plenty of zone flexibility and media storage capacity.
Part # 334-3125
  • Pentaplex Operations (Simultaneous Live, Recording, Playback, Network, Backup)
  • Individual control of Channel Recording Frame Rate, Resolution, Quality, and Audio settings
  • 3-year limited manufacturer's warranty
  • Viewer software for smartphone (iPhone, Android, Blackberry)
  • S.M.A.R.T. system health check and HDD recovery
  • Small form factor (two internal HDD)
  • 240 FPS recording and viewing
Make a Talos Security™ DVR the center of your surveillance system and experience true peace of mind. With features previously available only on high-priced and complex equipment, the Talos DRL Series is designed to meet professional standards and the budgets of an average small business or homeowner budget. H.264 video compression, along with selectable quality and resolution per camera, provides more recording time on the hard drive, while still preserving the recorded video's quality.
Network connection via the Ethernet port enables access to the DVR from any computer on your home network or across the Internet. Smartphone support facilitates viewing the DVR feed using an Android or iPhone handset. The system can be set to overwrite earlier video stored on the hard drive, so it never needs to stop recording. Viewing and archiving video content can be done easily using a USB drive or a computer connected to the DVR on your network.
Connect the video output to any TV with composite video input, modulate the signal for viewing throughout your house, or review high resolution video on a monitor. You can record video on the DVR continuously, by schedule, or by alarm to save on hard disk resources. The DVR's alarm can be triggered by an external device, like an alarm panel or contact, or by video motion detection built into the DVR operating software. Operate the DVR from the front panel buttons or wireless IR remote control, or use the intuitive GUI and a mouse to set-up, review, export, and back-up video easily.
Note: Hard drive not included, and must be purchased and installed separately.
Specifications: • Video compression: H.264 Advanced • Inputs: Video: 8; Audio: 4 • Outputs: Video: HDMI, VGA, Composite, Spot; Audio: 1 • Video display rate: Real time • Video display resolution: 1920 X 1080 • Video record rate: 240 FPS @ CIF • Video record resolution: CIF (320x240) 2CIF (640x240) D1 (640x480) • Operating mode: Pentaplex • Record mode: Schedule, Continuous, Event (Motion, Alarm) • Storage: Up to 2 internal HDD • HDD Included: No HDD • USB: Yes • Ethernet: Static IP, DHCP, DDNS • Alarm I/O: 8-In, 2-Out • PTZ: Yes • Power: AC 100V-220V (50 Hz-60 Hz) 60W • Dimensions: 2.76" H x 13.78" W x 10.16" D (70 x 350 x 258 mm).
  • TypeAnalog
  • Input Channels8
  • Hard Drive CapacityNo HDD
  • Commercial GradeYes
  • BrandTalos Security
  • ModelDRL800
  • Part Number334-3125
  • UPC848864004334
  • Product CategoryProducts
  • Weight6.4 lbs.
View similar products to the Talos Security DRL800 8-Channel H.264 DVR D1 120 FPS No HDD
in the Products product category.
