Talos Security DRL401 4-Channel H.264 DVR D1 120 FPS 1TB HDD
Brand:|Model: DRL401|Part # 334-3168
The Talos Security DRL401 4-channel commercial compact DVR system features an installed 1 terabyte hard drive, and provides plenty of zone flexibility and media storage capacity.
Part # 334-3168
  • Pentaplex Operations (Simultaneous Live, Recording, Playback, Network, Backup)
  • Individual control of Channel Recording Frame Rate, Resolution, Quality, and Audio settings
  • 3-year limited manufacturer's warranty
  • Viewer software for smartphone (iPhone, Android, Blackberry)
  • S.M.A.R.T. system health check and HDD recovery
  • Gigabit Network with dual stream support
  • Remote Firmware upgrade
Frequently Bought Together
Make a Talos Security™ DVR the center of your surveillance system and experience true peace of mind. With features previously available only on high-priced and complex equipment, the Talos DRL Series is designed to meet professional standards and the budgets of an average small business or homeowner budget. H.264 video compression, along with selectable quality and resolution per camera, provides more recording time on the hard drive, while still preserving the recorded video's quality.
Network connection via the Ethernet port enables access to the DVR from any computer on your home network or across the Internet. Smartphone support facilitates viewing the DVR feed using an Android or iPhone handset. The system can be set to overwrite earlier video stored on the hard drive, so it never needs to stop recording. Viewing and archiving video content can be done easily using a USB drive or a computer connected to the DVR on your network.
Connect the video output to any TV with composite video input, modulate the signal for viewing throughout your house, or review high resolution video on a monitor. You can record video on the DVR continuously, by schedule, or by alarm to save on hard disk resources. The DVR's alarm can be triggered by an external device, like an alarm panel or contact, or by video motion detection built into the DVR operating software. Operate the DVR from the front panel buttons or wireless IR remote control, or use the intuitive GUI and a mouse to set-up, review, export, and back-up video easily.
Specifications: • Video compression: H.264 Advanced • Inputs: Video: 4; Audio: 1 • Outputs: Video: HDMI, Composite; Audio: 1 • Video display rate: Real time • Video display resolution: 1920 x 1080 • Video record rate: 240 FPS @ CIF • Video record resolution: CIF (320x240) 2CIF (640x240) D1 (640x480) • Operating mode: Pentaplex • Record mode: Schedule, Continuous, Event (Motion, Alarm) • Storage: 1 HDD • HDD Included: 1TB SATA HDD • USB: Yes • Ethernet: Static IP, DHCP, DDNS • Alarm I/O: 4-In, 1-Out • PTZ: Yes • Power requirements: 100~220 VAC, 50~60 Hz • Dimensions: 1.38" H x 11.61" W x 7.17" D (35 x 295 x 182 mm).
  • TypeAnalog
  • Input Channels4
  • Hard Drive Capacity1TB
  • Commercial GradeYes
  • BrandTalos Security
  • ModelDRL401
  • Part Number334-3168
  • UPC848864006833
  • Product CategorySurveillance DVRs
  • Weight5 lbs.
View similar products to the Talos Security DRL401 4-Channel H.264 DVR D1 120 FPS 1TB HDD
in the Surveillance DVRs product category.
