Talos Security DC960V In/Outdoor Vari-focal IR Vandal Dome Camera 700TV Lines 2.8-12mm Lens
Brand:|Model: DC960V|Part # 334-012
The Talos DC960V Vandal-Proof Dome IR Camera is a secure and durable device that does its job, night or day, whatever the weather. Its varifocal lens ensures a crisp image.
Part # 334-012
  • 3‐axis easy to install mount
  • IR illumination for night-time viewing up to 75 feet
  • Durable die cast aluminum housing and polycarbonate dome
  • IP66 rating means the camera is weatherproof
  • 2.8~12mm adjustable lens for optimal viewing
  • UTP (up the coax) control
  • Digital Wide Dynamic Range
Vandal-proof dome cameras are designed to survive outdoor and abusive applications. A rugged, heavy duty aluminum die-cast housing features rubber o-ring seals to protect from moisture ingress. An optional wall mount provides an attractive way to mount the camera and conceal the cabling. This dome housing was designed with the professional installer in mind; easy access to mounting holes and a tether that holds the upper dome while camera adjustments are made makes installations smoother. Captive screws are used to secure the upper and lower dome housing, so you don’t need to worry about dropping them when you are on a ladder.
Able to survive a direct hit from a bat, club, or hammer, the polycarbonate dome will not cloud over time. A black cowl houses the IR LEDs and surrounds the lens, making it difficult to tell which area the camera is observing. Use this camera inside or outside and in direct contact with rain and water. The gimbal camera mount within the housing makes aiming the camera effortless.
The camera features a 1/3” Sony CCD Effio-e that produces 960H 700TV lines of resolution while 30 IR LEDs illuminate the darkness up to 75 ft. and turn on automatically when ambient light falls below 1 lux. A 2.8~12mm varifocal lens allows you to set the cameras viewing area to your specific needs. This camera will work with virtually any surveillance system, TV, or VCR with a composite video input; video output 1Vp-p at 75 ohms. The camera operates on 12VDC power.
Specifications: • Image Device: 1/3" Sony Effio-E • Camera Resolution: 700 lines • Minimum Illumination: 0 lux • White Balance: Switchable • Gain Control: Switchable • BLC: Switchable • Lighting Level Control: Electronic Shutter • Lens: 2.8~12 mm • Power Requirement: 12V DC.
  • Camera TypeDome
  • Special FeaturesIR Illumination,Indoor/Outdoor,Vandal Proof,Varifocal Lens
  • Operating Voltage12 VDC
  • Resolution700 TVL
  • BrandTalos Security
  • ModelDC960V
  • Part Number334-012
  • UPC848864013190
  • Product CategorySurveillance Cameras
  • Weight2.4000 lbs.
View similar products to the Talos Security DC960V In/Outdoor Vari-focal IR Vandal Dome Camera 700TV Lines 2.8-12mm Lens
in the Surveillance Cameras product category.
