334-144_ALT_0
334-144_ALT_1
334-144_ALT_2
334-144_ALT_3
Talos Security DC2420 In/Outdoor Dome Camera 420 Lines 3.6mm Lens
Brand:|Model: DC2420|Part # 334-144
Vandal dome cameras are designed to survive when lesser cameras are scattered across the floor. Camera features a 1/3" Sony Super HAD CCD that produces 420 lines of resolution. 1.0 lux illumination means this camera is still useful when only the nigh-lights are on inside the observation area.
Part # 334-144
  • 1/3" Sony Super HAD CCD
  • 420 lines of resolution
  • Heavy duty aluminum housing
  • High-impact polycarbonate dome
  • Only 4-1/4" diameter
Vandal dome cameras are designed to survive when lesser cameras are scattered across the floor. The rugged, heavy duty aluminum housing is precisely machined from solid aluminum. The upper and lower housings interlock and feature an o-ring to help keep moisture and dirt away from the camera. The polycarbonate dome will not cloud over time and will survive a direct hit from a bat, club or hammer. The shape of the camera is specifically designed to make it difficult to grasp and is almost impossible to pull off a wall or ceiling. The camera can be used inside or outside (must be located out of direct rain). The multiple mounting configurations allow the camera to mount on the wall or ceiling and a black camera cowl inside the dome makes it difficult to tell the area the camera is observing. Camera features a 1/3" Sony Super HAD CCD that produces 420 lines of resolution. 1.0 lux illumination means this camera is still useful when only the nigh-lights are on inside the observation area. Connect to any surveillance system, TV or VCR with a composite video input; video output 1 Vp-p at 75 ohms. Electronic shutter adjusts automatically to keep the image consistent as lighting conditions change. Back-light compensation helps the subject stand out against bright backgrounds; like a subject standing in an entrance way. Includes a 3.6mm wide angle lens.
Specifications: • Image device: 1/3" Sony Super HAD Color CCD • Resolution: 420 lines • Picture elements: 510 x 492 • Minimum illumination: 1.0 lux • Synchronization: internal • White balance: Auto • Gain control: Auto • Back light compensation: Auto • Electronic shutter: 1/20,000 • Lens: 3.6mm • Video output: 1Vp-p at 75 ohms via BNC female connector • Power: 12VDC, 150 mA via a 5.5 mm x 2.1 mm DC jack (power supply sold separately) • Dimensions: 3" H x 4-1/4" Dia. • Weight: 0.6 lbs.
  • Camera TypeDome
  • BrandTalos Security
  • ModelDC2420
  • Part Number334-144
  • UPC844632087790
  • Product CategorySurveillance Cameras
  • Weight0.9 lbs.
View similar products to the Talos Security DC2420 In/Outdoor Dome Camera 420 Lines 3.6mm Lens
in the Surveillance Cameras product category.
