Talos Security DC1080PFIR HD-SDI 1080p Indoor IR Dome Camera 3.6mm Lens 12 VDC
Brand:|Model: DC1080PFIR|Part # 334-405
The Talos Security DC1080PFIR dome camera is able to capture and send HD digital signals over standard RG59 cable. The 3.6 mm lens gives you a wide angle to make sure you don't miss anything.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
Part # 334-405
  • 1/2.5" CMOS 3 Megapixel sensor
  • Full HD resolution 1920*1080 30fps
  • ICR True Day & Night
  • Color: 0.1lux @F1.2; B/W: 0 Lux (IR ON)
  • 12VDC Power
  • RS-485 control
  • 3.6mm lens
HD-CCTV Camera Features include: 3DNR (3 Dimensional Digital Noise Reduction) function removes video noise in dark environments providing clear images as a result. TDN (True Day & Night) function always provides clear video images by distinguishing between day time and night time. During the nights, the TDN mechanism removes the IR-Cut filter to gather more light. This also includes infra-red light sources as well. The Digital Wide Dynamic Range (DWDR) enables the capture and display of light and dark areas in the same frame, in a way that there are details in both areas. For example, bright areas are not saturated, and dark areas are not too dark. 3.6mm lens gives you a wide angle of viewing that is great for most surveillance applications.
HD-SDI stands for High Definition Serial Digital Interface in compliance to standards developed by the Society of Motion Picture and Television Engineers (SMPTE) This allows bit rates of 1.485 Gbit/s (aka. SMPTE 292M) which is used in HDTV production and broadcasting in 720P and 1080p resolutions. The medium used to transmit HD-SDI video is based on RG59 75 Ohm coaxial cable for over at least 100 meters. For these reasons, an HD-SDI system is an ideal choice for users who are interested in upgrading their existing systems to high definition without having to install new cables.
Specifications: • Image Device: 1/2.5" Progressive scan CMOS • Camera Resolution: 1080P Full HD • Minimum Illumination: 0 Lux LED on • White Balance: Auto • Gain Control: Auto • BLC: Switchable • Lighting Level Control: DC Automatic Iris • Lens: 3.6 mm • Power Requirement: 12V DC.
  • Camera TypeDome
  • Special FeaturesHD-SDI 1080p (Full-HD),IR Illumination,Indoor Only
  • Operating Voltage12 VDC
  • Resolution1080p
  • BrandTalos Security
  • ModelDC1080PFIR
  • Part Number334-405
  • UPC848864013275
  • Product CategorySurveillance Cameras
  • Weight1.3000 lbs.
View similar products to the Talos Security DC1080PFIR HD-SDI 1080p Indoor IR Dome Camera 3.6mm Lens 12 VDC
in the Surveillance Cameras product category.
