Talos Security BC1080PFIR HD-SDI 1080p In/Outdoor IR Bullet Camera 3.6mm Lens 12VDC
Brand:|Model: BC1080PFIR|Part # 334-401
The Talos Security BC1080PFIR bullet camera is able to capture and send HD digital signals over standard RG59 cable. The 3.6 mm lens gives you a wide angle to make sure you don't miss anything.
Part # 334-401
  • 1/2.5" CMOS 3 Megapixel sensor
  • Full HD resolution 1920*1080 30fps
  • True Day & Night with ICR for good images at night
  • Color: 0.1lux @F1.2; B/W: 0 Lux (IR ON)
  • 12VDC Power
  • 3.6mm Lens
HD-CCTV Camera Features include: 3DNR (3 Dimensional Digital Noise Reduction) function removes video noise in dark environments providing clear images as a result. DN (True Day & Night) function always provides clear video images by distinguishing between day time and night time. During the nights, the TDN mechanism removes the IR-Cut filter to gather more light. This also includes infra-red light sources as well. The Digital Wide Dynamic Range (DWDR) enables the capture and display of light and dark areas in the same frame, in a way that there are details in both areas. For example, bright areas are not saturated, and dark areas are not too dark. IR LED's make it possible to see in the dark!
HD-SDI stands for High Definition Serial Digital Interface in compliance to standards developed by the Society of Motion Picture and Television Engineers (SMPTE) This allows bit rates of 1.485 Gbit/s (aka. SMPTE 292M) which is used in HDTV production and broadcasting in 720P and 1080p resolutions. The medium used to transmit HD-SDI video is based on RG59 75 Ohm coaxial cable for over at least 100 meters. For these reasons, an HD-SDI system is an ideal choice for users who are interested in upgrading their existing systems to high definition without having to install new cables. 3.6 mm lens gives you a wide angle viewing area to meet most applications.
Specifications: • Camera Style: Bullet • Image Device: 1/2.5" Progressive scan CMOS • Camera Resolution: 1080P Full HD • Minimum Illumination: 0 Lux LED on • White Balance: Auto • Gain Control: Auto • BLC: Switchable • Lighting Level Control: DC Automatic Iris • Lens: 3.6 mm • Power Requirement: 12V DC.
  • Camera TypeBullet
  • Special FeaturesHD-SDI 1080p (Full-HD),IR Illumination,Indoor/Outdoor
  • Operating Voltage12 VDC
  • Resolution1080p
  • BrandTalos Security
  • ModelBC1080PFIR
  • Part Number334-401
  • UPC848864013251
  • Product CategorySurveillance Cameras
    (1 Reviews)
  • Weight1.3500 lbs.
View similar products to the Talos Security BC1080PFIR HD-SDI 1080p In/Outdoor IR Bullet Camera 3.6mm Lens 12VDC
in the Surveillance Cameras product category.
