Talent HLZ1 Passive Direct Box
Brand:|Model: HLZ1 |Part # 233-160
Talent's HLZ1 passive direct box belongs in every audio professional's toolbox. Its transformer-balanced XLR output, switchable attenuation settings, and selectable ground lift option make it a versatile and dependable problem solver.
List Price$34.99
You Save44%
Buy 4+$17.78
Part # 233-160
  • 1/4" unbalanced, high-impedance input accepts most line level or instrument sources
  • 1/4" parallel output passes signal to stage amp and tuner, monitor, etc.
  • XLR balanced, low-impedance output drives long lines to mixer
  • Three attenuation settings to handle any input level: 0 dB, -20 dB, and -40 dB
  • Ground lift eliminates hum or buzz caused by ground loops
  • Passive operation requires no batteries or external power source
  • Roadworthy heavy-duty steel case with durable finish, along with recessed switches and connectors -- beware of flimsy imitations!
The Talent HLZ1 direct box converts high impedance, unbalanced audio signals to low impedance, balanced audio signals that are compatible with most XLR mixer or power amplifier inputs. The HLZ1's passive transformer circuitry requires no batteries or phantom power in order to operate, and the heavy-gauge steel enclosure will withstand years of handling and abuse.
Bi-directional functionality enables the Talent HLZ1 direct box to also be used as either a 1/4" high impedance to XLR low impedance converter, or an XLR low impedance to 1/4" high impedance converter; some additional adapter connectors or cables may be required. Set the attenuation switch to 0 dB when connecting the low level, high impedance signal from a guitar or other musical instrument. Choose the -20 dB setting for a keyboard, mixer, or line level component. At -40 dB, use the HLZ1 with a speaker level signal to feed the mixed sound from a guitar rig into the mixer.
Specifications: Frequency range: 15 - 30,000 Hz • Input impedance: 50,000 ohms • Input connector: 1/4" TS, monaural • Output impedance: 600 ohms • Power supply (not included): DC 9V center negative (-); 2.1 x 5.5 mm plug • Output connector: XLR male, balanced • Dimensions: 3" x 1.8" x 5.1".
  • Active / PassivePassive
  • Rack MountableNo
  • BrandTalent
  • ModelHLZ1
  • Part Number233-160
  • UPC848864016511
  • Product CategoryDirect Boxes
  • Weight1.5500 lbs.
View similar products to the Talent HLZ1 Passive Direct Box
in the Direct Boxes product category.
Part # 233-160
