233-131_ALT_0
233-131_ALT_1
233-131_ALT_2
233-131_ALT_3
233-131_ALT_4
Talent DM3PAK DynaMic Microphone 3-Pack with Case
Brand:| Model: DM3PAK
Product Video
Don't spend more than you have to for "legendary" performance. Talent's DM3PAK includes three custom-tuned DynaMic microphones that adds life to your vocal performance. Three mic clips and a ruggedized travel case are also included. Talent microphone cables sold separately.
  • Three microphones for the price of one from the leading competitor
  • Sound quality that rivals, and exceeds, that of "legendary microphones"
  • Cardioid polar pattern for focused sound capture and less feedback
  • Includes three memory-form mic clips with 5/8"-27 TPI threads
  • Built to withstand a 6 foot drop onto concrete
  • 45-day money-back guarantee
233-131
Weight: 3.8500 lbs.
IN STOCK
List Price$49.99
You Save32%
$33.80
Buy 2-9 $29.90
Buy 10-up$27.50
Part # 233-131
Talent's DynaMic handheld microphone is tuned for a specific frequency response that accentuates your voice, capturing every nuance with crystal clear clarity. The DynaMic's rugged body and hardened mesh steel grill protect the dynamic capsule cartridge from accidental drops—it's built it to withstand a 6 foot drop onto concrete—and the wear that comes from touring.
A weather-resistant capsule, integrated wind screen, and custom tailored output impedance combine to make the DynaMic your microphone of choice for outdoor performances and high SPL events. Not only does the integrated wind screen filter out unwanted gusts of air, it also acts as a pop filter and reduces breathing noise.
The durable power switch (for on-stage control) features positive tactile feedback detents—no more embarrassing, "Is this thing on?" guesses in front of a live audience. High quality, nickel-plated XLR contacts maximize signal transfer and resist corrosion.
Talent's DM3PAK packages three DynaMics together in a ruggedized microphone travel case. The internal protective foam is laser-cut for a precise placement of the microphones, and the three included microphone clips, as well as maximum protection.
Still not convinced? Talent is convinced that once you try a DynaMic, the only thing you'll remember about those "legendary microphones" is the legend. All Talent DynaMic microphones come with a 45-day, money-back, no-questions-asked, satisfaction guarantee. Talent microphone cables sold separately.
DynaMic Specifications: • Capsule type: Dynamic • Frequency response: 80 to 16,000 Hz • Polar pattern: Cardioid, unidirectional • Output impedance: 500 ohms • Sensitivity: -54 dB (0 dB=1V/Pa at 1 kHz) • Dimensions: Body diameter: 1-1/4" tapering down to 7/8" at the base, Grill diameter: 2", Overall length: 6-1/2" • Connector: 3-pin XLR.
Mic Clip Specifications: • Entry diameter: 1-1/16" • Exit diameter: 31/32" • Threads: 5/8"-27 TPI.
  • Element TypeDynamic
  • Polar PatternCardioid
  • On/Off SwitchYes
  • BrandTalent
  • ModelDM3PAK
  • Part Number233-131
  • UPC848864013527
  • Product CategoryVocal Handheld Microphones
    (5 Reviews)
  • Weight3.8500 lbs.
View similar products to the Talent DM3PAK DynaMic Microphone 3-Pack with Case
in the Vocal Handheld Microphones product category.
Talent DM3PAK DynaMic Microphone 3-Pack with Case is rated 4.4 out of 5 by 5.
Rated 4 out of 5 by from Very impressive for such inexpensive micsI own a small bar that has karaoke during the week and live entertainment on the weekends. I wanted to provide mics that were inexpensive and bullet proof with a decent sound. I've been a musician for 45 years and was an audio sales rep for 25 years and am fairly picky. I took a chance on the glowing copy that Parts Express uses for the mics, and I have to say, it's pretty accurate.The mics feel similar to 58's in your hand and are very solid. Their eq curve is a little flatter, not having quite as much HF emphasis. A little eq boost andthey did the job. The switch is firm and seems like it will be durable. For my purposes at the bar, it's the perfect solution. Would I use them regularly for my own band, probably not. But for budget minded situations, it's a great option.
Date published: 2014-11-14
Rated 5 out of 5 by from Good Sounding MicsI purchased 2 sets of these for a School. The price is great and the quality is good. As with many mics of this design, they are prone to "P" popping. Otherwise, accept for the most critical of uses, these mics qualify as a good deal and seem to be sturdy in their construction
Date published: 2014-09-26
Rated 4 out of 5 by from Great value, but modify mic clipsOnly negative is the mic clips don't really allow the mic to be removed, the gap on top is too narrow. Was able to cut the slot a little wider with a dremmel tool to just wide enough for the mic cable to pass through.
Date published: 2014-07-09
Rated 5 out of 5 by from Great sound for a decent priceGood to keep around a few decent extra mics. The case are an easy storage bonus too.
Date published: 2014-05-17
Rated 4 out of 5 by from microphonesHave not used them yet but expect they will fill the need at my church.
Date published: 2014-05-16
  • 2015-03-30T07:32CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_233-131, PRD, sort_mostRecent
Videos
Customer projects that include: Talent DM3PAK DynaMic Microphone 3-Pack with Case
