244-504_ALT_0
244-504_ALT_1
244-504_ALT_2
244-504_ALT_3
244-504_ALT_4
Talent BL252 Multi-color 42" LED Linear Strip Lighting Bar with Bracket 252 LEDs
Brand:|Model: BL252|Part # 244-504
The Talent BL252 LED RGBW lighting bar fixture is an ideal instrument for creating powerful wash lighting or exciting stage effects. The inclusion of white LEDs increases overall output and provides more options for color rendering.
List Price$199.99
You Save50%
$99.87
Buy 4-11 $95.50
Buy 12+$89.90
Part # 244-504
  • Provides the punch and coverage demanded by larger stages, floors, and walls
  • Cool-running, high output, low power consumption 252 LED fixture
  • Auto, sound active, DMX, and master/slave modes
  • Internal programs with sound activation for hands-free effects
  • RGBW color mixing enables customization, including brilliant white light
  • Easy pushbutton programming via alpha-numeric display
  • Slimline robust aluminum housing withstands the rigors of portable use
Add bright splashes of color to stages, parties, and dance floors. Talent Sound & Lighting's BL252 LED "batten" fixture is operable as a stand-alone RGBW (red/green/blue/white) device that runs on pre-programmed routines or sound activation, in master/slave mode with other BL252s, or via a user-supplied external DMX512 controller. In DMX mode it is configurable for 2, 7, 10, or 31 channel operation.
Up to sixteen BL252 fixtures are linkable and will auto-run without a controller. In Master/Slave mode, the first fixture will control the others to give an automatic, sound activated, synchronized light show. Quick, easy, and spectacular! The first, or master, fixture's DMX input will have nothing connected to it. Its output connects to the remaining fixtures, which will be set in slave mode automatically. For completely hands-free operation, simply set the BL252 to sound activation mode and let music control the show automatically.
The BL252's active components are housed in a slim, all-metal enclosure that features dual mounting yokes for hanging the fixture or standing it on any flat surface. IEC power in/Edison power out connectors make it easy to daisy chain electrical cables, and on-fixture programming is accomplished via pushbuttons and a digital display. Male and female 3-pin XLR connectors are furnished for DMX data input and loop-through.
Specifications: • LEDs: 252 Ultra Bright 10 mm (Red: 63, Green: 63, Blue: 63, White: 63) • DMX channels: 2/7/10/31 • Modes: Auto, sound active, DMX, master/slave • Beam angle: 40° • Control input: DMX 3-pin XLR male and female • Power input: 90~250 VAC, 50-60 Hz • Power consumption: 23 watts • Dimensions: 42.91" L x 2.64" H x 2.64" W • Weight: 4.07 lbs.
  • Light TypeLinear Strip
  • DMX-ControllableYes
  • BrandTalent
  • ModelBL252
  • Part Number244-504
  • UPC848864007755
  • Product CategoryWash Lights / Stage Lighting
    (3 Reviews)
  • Weight6.5500 lbs.
View similar products to the Talent BL252 Multi-color 42" LED Linear Strip Lighting Bar with Bracket 252 LEDs
in the Wash Lights / Stage Lighting product category.
Videos
