T-Amp Tripath TA2024 2x15W Audio Digital Amplifier Board
Brand:|Model: TA2024
The T-Amp revolution continues here! This compact stereo amplifier based on the Tripath TA2024 chip outputs 2 x 15 watts and is perfect for building into audio projects or use as a standalone amp.
List Price$19.99
Regular Price$13.80
You Save28%
Sale Price
$9.98
Part # 320-600
  • Pre-assembled, pre-tested for easy project integration
  • Class T fidelity and energy efficiency
  • 2 x 15W continuous power, adequate for most speakers
  • Requires only 12 VDC 2 A
This board is designed around the Tripath TA-2024 integrated circuit. The TA2024 is a 15W/channel continuous average two-channel Class-T Digital Audio Power Amplifier IC using Tripath's proprietary Digital Power Processing™ technology. Class-T amplifiers offer both the audio fidelity of a Class-AB amplifier and the power efficiency of a Class-D amplifier.
Perfect for projects, this board features over-current and over-temperature protection circuits. It can be built into powered speakers or used as a standalone amplifier. The board's small size is even ideal for inclusion in OEM products or store displays.
Specifications: • Output power: 9W x 2 @ 4 ohms (0.04% THD+N), 11W x 2 @ 4 ohms (0.1% THD+N), 6W x 2 @ 8 ohms (0.1% THD+N), 15W x 2 @ 4 ohms (10% THD+N), 10W x 2 @ 8 ohm (THD+N) • IHF-IM: 0.18% @ 1W, 4 ohms • Efficiency: 88% @ 10W, 8 ohms • Dynamic range: 102 dB • Recommended power: 12 VDC, 2A • Dimensions: Board: 3.54" x 2.09" (90 x 53 mm); Mounting holes (center to center): 2.88" x 1.81".
  • BrandParts Express
  • ModelTA2024
  • Part Number320-600
  • UPC4442524341560
  • Product CategoryAudio Amplifier Boards & Modules
    (14 Reviews)
  • Weight0.1 lbs.
View similar products to the T-Amp Tripath TA2024 2x15W Audio Digital Amplifier Board
in the Audio Amplifier Boards & Modules product category.
T-Amp Tripath TA2024 2x15W Audio Digital Amplifier Board is rated 4.2143 out of 5 by 14.
Rated 5 out of 5 by from Great tinker amp!I bought one to replace a busted T-Amp I had and I wanted a summer amp that didn't make a lot of heat. Immediately replaced all the electrolytic caps and the output chokes with spare 41hz toroids I had wound. Running off a 12v computer supply and driving a pair of super high efficiency folded horns. This little amp does allright. +1
Date published: 2015-04-22
Rated 5 out of 5 by from supised by power and qualityyes i bought this with 2 Fountek FE83 3" Full Range Driver 8 Ohm speakers and built a portable boombox with a 12v 8ah battery. the quality is great and the sound is louder than expected. can not wait to use this amp for future projects!
Date published: 2015-03-26
Rated 5 out of 5 by from Simple is good -- comparison to the Dayton DTA-2Doesn't have all the features as the DTA-2 module, no volume control, LED pilot, and lacking fixed power and audio plug-in connectors, but much simpler to hook up because requires less soldering. Just need to solder up an audio connection and everything else uses screw terminals.I like the sound of these. Not quite as bright as the DTA-2 modules and the low end seems more even. Plenty of power for most speakers of reasonable efficiency.The build quality is superior to the DTA-2 as well where I've seen marginal solder and circuit board issues. I've built about 6 portable speaker boxes using these and haven't experienced any problems yet.
Date published: 2015-03-12
Rated 4 out of 5 by from Great DesignI've owned several of these boards. They sound excellent once modded. Quality isn't the greatest, the solder traces on the board are easily ruined, and the parts are cheap. The audiophiller caps are a little bright. The good thing is all the major parts are accessible, and can be removed with care. Also the price is a wonderful value. Put some good parts on it, and it will surprise you.
Date published: 2014-12-14
Rated 2 out of 5 by from These amps sound good but run hotI bought 3 of third after the first two failed on me I used the last one briefly then upgraded to leapai 2020a+.These are plenty loud but run hot. I only used them for 3 weeks before burnout.i did have them properly wired to potentiometers wired from a 3.5 mm phone jack.maybe I did something wrong but to sum it up these amps suck.upgrade to leapai IMHO .
Date published: 2014-09-10
Rated 5 out of 5 by from Perfect project ampMy son has a kicker stereo that the amp when bad in but I couldn't bring myself to throw it away. This little tripath amp was the answer. Its' small size worked out better than I hoped, easy to install and sounds great. I don't have a 2 amp power supply at 12v but found that it works great with a 9v supply. Don't try to run a power supply over 12v or the amp will shut itself down.
Date published: 2014-08-09
  • 2015-08-02T06:42CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_14
  • loc_en_US, sid_320-600, PRD, sort_mostRecent
how do I wire in a Volume Control? Can I get a copy of the manual for the device I purchased? The TA2024 2X15W
Asked by: Rayme31
Look at the Suggested Diagrams PDF file to the right of the item picture in the web page.
Answered by: jajke
Date published: 2015-04-10
Can I run only one channel
Asked by: KF7ZFC
Yes.
Date published: 2015-02-11
How could I wire multiple audio inputs to this amp? I would like to have a switch that toggles between a 3.5mm input (Part # 090-317) and Bluetooth input (Part # 320-351).
Asked by: desain2
You will need a single-throw switch with three poles, which can connect or disconnect the left, right, and ground input pins for either source all at the same time. You may hear a "pop" when selecting inputs this way.
Answered by: DaytonAudio_Rory
Date published: 2014-11-25
How would I connect a bluetooth adapter to the red white and black wires coming out of the 3 pin JST-PH wire harness?
Asked by: rpritch5
This depends on the Bluetooth adapter you want to use. If it has a 3.5mm input, you will have to solder a 3.5mm plug to the end of the signal cable. You can see examples of this wiring in the manual below.www.parts-express.com/pedocs/manuals/320-600-parts-express-ta2024-manual.pdf
Date published: 2015-01-09
I would like to waterproof this amplifier but encasing it in an epoxy resin or silicone sealant but I am concerned with the heat build up. How hot do these little amps get and would completely encasing it make it run too hot?
Asked by: Jake Jarmon
The chips on these amplifiers will get warm. I would not recommend encasing them in a waterproof epoxy but it has not been tried as far as I know. Doing this will void any warranty but for the price you can always try one to see if it has any ill effects before a permanent install.
Date published: 2014-04-10
Is it possible to order extra audio-in connect cables?
Asked by: djfake
Unfortunately we do not offer these separately.
Date published: 2014-04-08
  • 2015-08-02T08:59CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • co_hasquestionsanswers, tq_19
  • loc_en_US, sid_320-600, PRD, sort_recentQuestionsFirst
