320-602_ALT_0
320-602_ALT_1
320-602_ALT_2
T-Amp Tripath TA2021 2x20 Class-T Audio Amplifier Board
Brand:|Part # 320-602
This amplifier board features Tripath's TA-2021 IC with 20 watts per channel power output.
Part # 320-602
  • Pre-assembled and pre-tested for easy project integration
  • Class T fidelity and energy efficiency
  • 2 x 20W continuous power, adequate for most speakers
This board is designed around the Tripath TA-2021 integrated circuit, a 40W two-channel Class-T digital audio power amplifier using Tripath's proprietary Digital Power Processing™ technology. Class-T amplifiers offer both the audio fidelity of a Class-AB amplifier and the power efficiency of a Class-D amplifier. Includes speaker wire leads that plug into board.
Perfect for projects, this board features over-current and over-temperature protection circuits. It can be built into powered speakers or used as a standalone amplifier. The board's compact design is ideal for inclusion in OEM products or store displays.
Specifications: • Power: 2 x 20 watts @ 4 ohms, 2 x 13 watts @ 8 ohms • Efficiency: 81% @ 4 ohms, 88% @ 8 ohms • Signal/noise ratio: 100 dB • Signal Input: 3 pins • Signal Output: 4 wires signal output • PCB Thickness: 1.6 mm • PCB material: glass fiber • Power Requirements: 8-14.5 VDC • Dimensions: 3.54" x 2.09"
  • Special FeaturesClassT;BoardOnlyModule
  • BrandParts Express
  • Part Number320-602
  • UPC848864006123
  • Product CategoryHome Audio Amplifiers
    (5 Reviews)
  • Weight0.15 lbs.
View similar products to the T-Amp Tripath TA2021 2x20 Class-T Audio Amplifier Board
in the Home Audio Amplifiers product category.
