245-5332_ALT_0
Switchcraft SC900CT Instrument DI Box with Phantom Ground Lift
Brand:|Model: SC900CT|Part # 245-5332
ORDER TODAY
Ships in 7-10 Business Days
List Price$158.00
You Save37%
$99.99
Part # 245-5332
  • Phantom Lift: remote-controllable ground lift uses phantom power to trip ground line
  • LED indicator illuminates to show lifted ground
  • Manual mode or automatic
  • Defeatable 20dB pad
  • Durable aluminum construction
Switchcraft's 900 Series is a revolutionary new concept in DI technology. For the first time, the ground lift can be controlled remotely using +48V phantom power from the console! The unit can be operated in two modes. Manual mode enables the user to control the ground lift switch from the DI using the toggle switch. Phantom mode allows the user to control the ground lift remotely using +48V phantom power from the console. When phantom power is applied, an LED is illuminated indicating that the ground is lifted. When phantom power is turned off, the LED turns off indicating that the DI is grounded. The SC900CT also comes equipped with a Switchcraft custom transformer, so you get amazing isolation, impedance matching, and absolutely crystal-clear, noise-free operation.
Specifications: • Frequency response: 20 - 20,000 Hz (+/- 3 dB) • Total harmonic distortion: <0.008 % @ 1 kHz • Input impedance: 110k ohms • Output impedance: 20 ohms • Maximum Input level: +19 dBu @ 20 Hz/1%THD • Dimensions: 4.16" x 3.35" x 2.10" • Weight: 1.2 lbs.
  • Active / PassivePassive
  • Rack MountableNo
  • BrandSwitchcraft
  • ModelSC900CT
  • Part Number245-5332
  • UPC848864001784
  • Product CategoryDirect Boxes
  • Weight1 lbs.
View similar products to the Switchcraft SC900CT Instrument DI Box with Phantom Ground Lift
in the Direct Boxes product category.
Videos
