Switchcraft SC900 Instrument DI Box w/Jensen Transformer & P
Switchcraft SC900 Instrument DI Box w/Jensen Transformer & Phantom Lift
Brand:|Model: SC900|Part # 245-5330
Part # 245-5330
  • Phantom Lift: remote-controllable ground lift uses phantom power to trip ground line
  • LED indicator illuminates to show lifted ground
  • Manual mode or automatic
  • Defeatable 20dB pad
  • Durable aluminum construction
Switchcraft's 900 Series is a revolutionary new concept in DI technology. For the first time, the ground lift switch can be controlled remotely using +48V phantom power from the console! The unit can be operated in two modes. Manual mode enables the user to control the ground lift switch from the DI using the toggle switch. Phantom mode allows the user to control the ground lift switch remotely using +48V phantom power from the console. When phantom power is applied, an LED is illuminated indicating that the ground is lifted. When phantom power is turned off, the LED turns off indicating that the DI is grounded.
Specifications: • Frequency response: 20 - 20,000 Hz (+/- 3 dB) • Total harmonic distortion: <0.008 % @ 1 kHz • Input impedance: 110k ohms • Output impedance: 20 ohms • Maximum Input level: +19 dBu @ 20 Hz/1%THD • Dimensions: 4.16" x 3.35" x 2.10" • Weight: 1.2 lbs.
  • Active / PassivePassive
  • Rack MountableNo
  • BrandSwitchcraft
  • ModelSC900
  • Part Number245-5330
  • UPC848864001777
  • Product CategoryDirect Boxes
  • Weight1 lbs.
View similar products to the Switchcraft SC900 Instrument DI Box w/Jensen Transformer & Phantom Lift
in the Direct Boxes product category.
Videos
